All i can find on the internet is C 515 & C516 : IC 206 (jungle) i can not located these components in the back of the TV Can you help me
SOURCE: Convergence problem
you will need to replace the stk ic's they are mounted to 2 large heat sinks in side the tv. the ic numbers are on the chips themselves. i do believe it is stk392-510 for sony. once you have the number you can buy these anywhere online. just put new ones in and should be good to go. if this doesnt work then there are a few resistors and fuses by the ic's that sometimes fail.
SOURCE: Sony KP-46WT510 - Six Blinks
the deflection board is bad and they are real easy to replace...contact the manufacturer for the parts.
SOURCE: sont kp-46wt510 blinks 4 times
Could you send the service manual to me as well? Any idea what this might cost to fix? Thanks
email: [email protected]
SOURCE: Finding the convergence ic's
They are located on the D board attached to large aluminum heatsinks They have the numbers STK392-560 you will need to replace both of them. You can get new ones at this link and they will give you free installation instructions with free tech support to help you with doing the repair. here is the link.
http://servicemanuals.vstore.ca/
