My iPhone 3G Battery Life is ridiculously short is this common or is just my iPhone?
Is there anything I can do about this?
Thanks.
Hi guys!!!
mine has improved quite a bit in da last few days..follow da instructions 1.RESET NETWORK SETTINGS 2.SWITCH OFF ALL APPLICATIONS LIKE GPS,3G,WIFI,AUTOMATIC TIME UPDATE AND PUSH UNLESS U REQUIRE!!(SAD THOUGH!!) 3.FORCE QUIT EACH ICON INDIVIDUALLU AFTER OPENING DA ICON 4.BRIGHTNESS AT NEXT TO LOW(SWITCH OFF AUTO BRIGHT)
mine has gone 3hrs standby to 16hrs standby wit minimal usage..and 14hrs after moderate usage..its been increasing every other day..its spooky..its got a mind of its own..A.I kinda!!!
pleasr respond if my tips helped u out..cheers!!
frm abu dhabi(uae)
Try turning off bluetooth, if 3G turn off that, push data setting and turn of auto contrast.
Hope This Helps....
All of the iPhones have the ability to connect to an external
battery, a charger, or any computer with a USB port. You only need a
cable. Does your Treo charge from any USB port? And carrying a cable in
your bag is no harder than carrying an extra battery.
I don't
think you'll ever see a replaceable battery in an iPod or iPhone. It
would make the device too big and it would reduce the battery
life--that's right, battery life is worse with a removable battery
because the battery has to be smaller. However, you can be sure that
Apple will continue to push the chip makers for lower power chips
if this can't help you then add an comment i"ll solve it for you
