Need to check is pico fuses are blown after power surge on le19b450 LCD tv
SOURCE: proscan lcd tv model 26lb30h blows fuse on power board
If the fuse blows again after replacing it, there's a shorted diode, bridge rectifier, capacitor or transistor in the power supply.
I repair these power supplies. If you need furhter assistance, write to [email protected]
SOURCE: Have lcd tv samsung. Had a power surge now tv will
If you get no standby light or error blinks, the power supply board is bad. Most likely the power surge will take out some capacitors on the power supply. Replace the power supply board to solve the problem. This is a common failure caused by a power surge.
Note: If you are looking to do it the cheap way, you could try looking for bad capacitors (visually inspect for ones that look "bubbly") and replacing just those but it is not guaranteed to fix the TV as the power supply could have other issues and just cause the capacitors to bubble again.
SOURCE: Blown Fuse LG LCD
You should try looking for new power supply module. It may be cheaper that trying to have it fixed. Do you have any pictures. Hope fully the surge did damage the controller board.
SOURCE: Samsung LN52A650 lcd will not turn on after power
open it up / there should be a glass fuse replace it/ull find it were the mains lead goes on the board/also try new lead just incase
