I want to get what I would need to drill a hole in a china Plate to make a bird feeder Without breaking the plate.
Can you help me.?
Normally you would use a masonry bit to drill into ceramics eg tiles or bricks. if the plate is glazed it is better to stick some masking tape or adhesive backed paper on the area to be drilled to stop the drill bit slipping around. also i would be inclined to use a hand turned drill or a small battery powered drill if you have one to avoid breakage of the plate.
Use a masonery drill bit
what are the potential drill hole problems
