Hi
The handlebar for Quinny Buzz is not a spare part we can send out as it is a Level 3 repair which means our engineers must carry out replacement. This is due to safety implications of it being incorrectly fitted.
Please visit www.quinny.com and select the country you're in, then click "Contact Us" tab on right side of screen for your enquiry to be sent to customer care team in your country for further assistance.
SOURCE: have a quinny buzz frame,
go to http://www.user-manual-search.com/search.aspx?search=quinny%20buzz%20frame and choose the 6th tab down...download this manual and it should tell you everything you need to know.. easy as pie....hope this helps...
please rate, i appreciate it...
SOURCE: Buzz 2006 cracked foam on handle...replacement part?
Call your local bike store they might be able to fix it.
SOURCE: Main frame and worn wheels of the quinny buzz
This happened to my wife the other day, I found that the main pivot bolt had pulled through the plastic pivot/collapse assembly. This part is rivoted to the frame so without drilling it out and replacing with an ugly nut and bolt you will have to source a new frame. I got mine from Ebay, I found someone selling lots of quinny buzz bits and asked if he still has the frame he said yes but the handle bar no longer extends (Hence im on here looking how to swap the two), Problem solved!
I also found out from Quinny that the Buzz has a 2 year manufacturers warranty, where Motercare insisted it was 1 year, so dont let them fob you off.
Hope this helps
Chris.
SOURCE: does the quinny buzz seat 2006 and carrycot fit the 2008/9 frame
Hi new frame should be ok, the only frame that is different is the older 2005 frame, if you remove your seat unit and check the posts on your seat unit (the bits that slot onto the buzz chassis) if they are both the same and have rounded ends then this is the older model and wont fit the newer frames, but if one of the posts is rounded and the other is shaped like a turret then all the frames 2006 onwards will be ok. :)
SOURCE: replacement foam for quinny buzz handlebar
Hello
I am making handle bar, bumper bar and frame
covers for the bugaboo and can probably help you
with a cover. Contact me at www.bbsprouts.com
Diane
