SOURCE: hi i have a vision
Typically an E6 error message indicates that the machine needs to be recalibrated because the elevation motor is out of range or that you have a loose cable connection. Below are the auto calibration instructions. Please make sure that no one is on the machine because it will speed up quickly. STEP 1 ENTER ENGINEERING MODE With the safety key in place, hold "ELEVATION UP" and "SPEED DOWN" buttons for 5 seconds. Software version will appear in display window for a few seconds before model displays. Press "STOP" , "ENG1" will appear in display window. STEP 2 AUTO-CALIBRATE Press "ELEVATION UP" until "ENG4" is displayed. Press "SELECT" , display will read "AUTO". Press "START". Unit will calibrate, when finished "END" appears in display window, then "ENG1". STEP 3 EXIT ENGINEERING I would also suggest that, with the power to the machine off, you check all of the wire connections underneath the motor cover, the assembly connection that sits where the mast meets the console and underneath the faceplate. Check to be sure that all of the connections are secure and that the pins within the cables are seated properly. If you are still having any problems you can reach a knowledgeable Vision Fitness Representative toll free at 800-335-4348.
Press and hold "STOP" to exit engineering mode
SOURCE: My Vision Fitness treadmill reads E6 when I turn
This just means that the elevation is out of range. It probably lost its signal when you moved it. The way to fix this is to recalibrate it. You can do an auto recalibration.
