I am using a Zebra Z4mplus barcode printer. when I send print from the system the darkness of the printer dicreased.there for I can't get a clear print. then I possed the print and manually increase the darkness of the printer.then I will get the clear print. in next time the same is happening. I can't save the darkness of the printer permenantly.pls give solution for this issue
Go to printer driver properties..
1.click printing preferences set it to USE PRINTER CONFIGURATION
2.go to advance click Printing Defaults set it to USE PRINTER CONFIGURATION
you must set this two configuration
note: fresh installed driver defaulth to software control
Choose the software in the printer setting and find the parameters can be as heat setting or darkness.
If you are using ZPL commands, use ^MDxx (-30 to 30) or ~SDxx (00 to 30).
Am using a Zebra Z4mplus barcode printer. when I send print from the system the darkness of the printer dicreased.there for I can't get a clear print. then I possed the print and manually increase the darkness of the printer.then I will get the clear print. in next time the same is happening. I can't save the darkness of the printer permenantly.pls give solution for this issue
Please email me at .. [email protected] with a contact name and telephone number.
Im a qualified Zebra engineer. but need to know what sort of software yuo are printing from.
please email me at .. [email protected] with a contact name and telephone number.
Please advise what sort of software you are printing from.
Every time I print from a windows application to my zebra printer, it resets the 'darkness' back to 10. There is no way to set the darkness on the printer permanently to 15.
i have some problem of my printer zebra Z4MPlus when i print the barcode is not clear please help me to solve this problem.
Please help to adv when can i get the answer???Please forward answer to my e-mail is [email protected].
