Question about Sony BRAVIA KDL-V32XBR2 32 in. HDTV LCD
Sony KDL-V32XBR2 - no picture, no sound...I'm pretty sure the hdmi input port is damaged...is it worth it to repair/replace? and can I do it myself?
    Master:
  • Sony Master
  • 359 Answers
Yes ,you should replace the main board ,because you can'nt repair HDMI interface.
Abctay.com Wholesale tv parts,include TV power supply board, logic board, TV LED screen
Posted on Aug 02, 2018
6ya staff
SOURCE:
Anonymous
  • 320 Answers
SOURCE: HDMI Input Stopped Working Sony Bravia KDL-40S2000
Bad input board BU or AU
Posted on Oct 18, 2008
Anthony Gonzales
  • 267 Answers
SOURCE: Sony 46" LCD tv hdmi input replacement kdl-46v2500
replace that board
Posted on Mar 06, 2009
jeep brainy
  • 336 Answers
SOURCE: my Sony BRAVIA KDL-V32XBR2 32
please try differect sources e.g. dvd, cable TV box, aerial. Also check that your connectors are properly plugged in. If none of those work, bring your tv to the nearest service center.
cheers!
Posted on Jul 11, 2009
Anonymous
SOURCE: KDL-40V5100 TV HDMI Issue
I have the same problem did you ever find a solution
Posted on Apr 01, 2010
obanjo2
SOURCE: sony kdl-v32xbr2 - blank screen with volume.
Pull the power plug from the wall, and replug.
Posted on May 05, 2010
Sony tv no picture on screen
Hello, You probably hit the input button by mistake. If your using cable TV your input setting will depend on how the TV is connected. If your using an HDMI cable check to see what number HDMI the cable is plugging into on the back of your tv and then set the input button to the same port number. If your tv is connected with RCA cables (red,blue,green) Then hit the input to AV.
Feb 05, 2018 | Sony Televison & Video
Sony kdl-46z5100, good sound , no picture via hdmi ports. do get video using home function viewing internet choices and tools. Which board controls hdmi inputs ?
Whatever board is connected to the HDMI ports is the decoder board, this can be the main board or a separate board.
Feb 09, 2017 | Sony Televison & Video
Hello, I have a Sony Bravia KDL-46EX400 and after an incident the HDMI ports doesn't work anymore. I have checked the other ports (D-Sub / AV / Component) and they work OK, even the USB can reproduce 1080p...
There will be a damaged interface IC on the input board. It may be worth taking a look and ordering one if you are competant with desoldering etc or just order a complete input board.
Hope that helps.
Mar 10, 2011 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
No signal through hdmi ports
Check the hdmi cables be sure their in proper working condition, wiggle the cables around see if picture comes up. If not and the cables are good then the hdmi processor on the main board of your TV is defective. Alot of times hdmi ports tend to burn so see if you smell a burnt smell near or around the hdmi ports. but before you do anything be sure sure your TV settings are correct for hdmi....
Oct 18, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I have a broken LCD Screen SONY KDL V32XBR2 . Is it worth repairing it? Where can I get a LCD replacement and how much $$$?
No,LCD screen replacement,will cost same as a new tv.Even might be more after labors.Because LCD screen is limited produce,and it 90% of the tv.
Mar 11, 2010 | LG 42LC2D 42 in. LCD HDTV
My Sony BRAVIA KDL-V32XBR2 32 has lost its sound. I have checked that the speaker setting is on, the mute is off. Is there anything elsei I can check?
cheers!
Jul 11, 2009 | Sony BRAVIA KDL-V32XBR2 32 in. HDTV LCD
Sony BRAVIA  KDL-V32XBR2 32 in. HDTV LCD Logo
174 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
