I have noticed a few days ago that my tablet won't register my pen at a slightly off-center vertical column of my display (in widescreen orientation), an area about 1 inch wide. Since then, the tablet would intermittently switch between sensing the pen again at this column and back to not sensing. The sensing has not been flickering, leading me to believe that it is not some sort of loose internal connection (but I'm not sure). Touchpad mouse still works. Help would be wonderful!
SOURCE: gateway tablet screen does not respond to pen.
I have a Gateway CX2724 and previously had another Gateway tablet (model I don't remember) but they both look alike and use the same pens. I've had 3 pens and they all periodically stop working. When one stops, I pick up another pen and work with it so that makes me think the problem has more to do with the pen. (They have all died and later come alive.) Sometimes though I can't find the extra pen and have resorted to removing the working pen tip / nib and reinserting it very snugly after wiping off the shaft. The nib is held in merely by friction. You can remove it by pinching its little tip between your fingernails and pulling it straight out. I wipe off the shaft and put it snugly back in. Sometimes I don't take it out, but just press it harder into the pen by pushing it firmly onto a padded surface (so that the tip doesn't deform.) Usually one of these "treatments" works. I know that extra nibs are available with the pen. There must be some reason that the manufacturer thinks they may need to be replaced periodically. But I've never seen any documentation on this.
SOURCE: Problem with pen/software on Gateway M280E
First install the anti virus software then update the software then scan your computer after scan try again. if it cant work format your computer.
SOURCE: gateway tablet cx200X, tablet features won't work/ pen etc
All,
There is DEFINITELY A PEN IN THE CX2620 stylii. I just replaced mine with a AAAA battery. The old one (which is a AAAA size, you can find these inside 9-volt batteries) had acid buildup on its positive end and that is why the pen went inactive. There is a lot of debate over this pen problem and I guarantee 90% of the time it's related to the battery. I can do a clean replace on anybody's CX2620 pen/stylii with a fresh battery for $10. If interested email me at [email][email protected][/email] . You pay for shipping, your total about $17 or so. I have never done this before but I just replaced mine flawlessly so I can do others. I know there are a lot of dead stylii out there and people don't know what to do, took me a while to figure it out.
Thanks,
Kevin Teman
