SOURCE: Fisher and Paykel (Old model) Fresh 5.0
you probably have a foreign object in the pump impellor - the favourite is bits of bra wire
SOURCE: Washing machine not draining and finishing cycle
I had the same problem.... It would stop on the rinse cycle and beep. Check to make sure you can hear the water pump running or if you can just hear an electrical hum and then it quits, it may be a problem with the water pump.The water pump can be accessed by removing the tub, reach down the center of the agitator and remove plastic bolt, remove the stailess steel tub and then remove the plastic oval shaped cover at the bottom of the main tub to access the pump impellor. Make sure the impellor turns freely, if it does not you may have a problem with the pump motor. We had a gold chain go missing and it showed up wrapped around the pump shaft causing it to bind at times. It took me two tries to fix it but now it runs 100%.
SOURCE: Need to replace drain hose
there is a kit available to replace just the part from the back of the machine.normally the drain hose comes with the wiring loom big job.not sure what country you are in.kit is available in australia.
SOURCE: Fisher Paykel dryer
buzzing sound generally come from the motor assy, not necessarily a bad motor however. try opening the front door and along the inside of the top of opening is 2 phillips screws the top will tip back and then removing 2 5/16 screws from inside the font panel will remove giving you access to the motor blower assy.. it is possible that something( baby sock, small undergarment) has fallen inti the blower preventing free spin also resulting in a buzzing noise, if so simply remove debris and reassemble.
SOURCE: fisher & paykel (mw511)
check out the DRAIN MOTOR PUMP , its a small motor with 2 hoses connected to it , it could be clogged , need to remove it , inspect inside the impellers for any debri , clean it , re install and try again , hope this helpful AJ
