I install all speakers but only the fronto speakers are working. What I need to do??? I don´t have the manual...
Remove all the external connections from the back of the device and connect it properly again at proper places.everything is proper.its just the problem of wires not connected properly where they should be.try interchanging the wires from 1 jack to another and then check it will work with any other combination.
thanks
I think they're disconnected, if you need more jacks, just get an extender. and dont forget that the main speaker is the first one that should be installed. Thank you! Hope this is helpful
Can you please explain your problem further, are you still looking for teh replacement remote??
I think your only one channel active.
u need to active other chaanel.
http://tv.manualsonline.com/ex/mfg/headline/m/akai
You can get the manual from ...
http://safemanuals.com/user-guide-instructions-owner-manual/AKAI/CD3000XL-_E
You can buy the remort from here..
http://remotes.com/store/akai/dht300.html
let me know if you any more quaries
Thanks
Kevin
HI,
There is no original remote available but you can buy a replacement remote for your model and it will work like an original remote..
Please click on the below link:
You need to connect the other speaker to appropriate pin .
Check the settings .
Try a substitute remote control
Http://safemanuals.com/user-guide-instructions-owner-manual/AKAI/CD3000XL-_E owners maual ......... you need to change the settings on it for suround sound
http://www.remotes.com/?OVRAW=AKAI%20DHT... new remote control......... web site good luck
I want to buy the AKAI DHT 300 original remote control
I don´t understand what means the solution. Could you explain me more detail?? I have now the remote control. What´s weblord?? Thanks.
I installl everyting and now the front and the subwofer are working...Probably the other channels are disconnected????Thnaks...
OK, right now nobody can solve my DVD Receiver Akai DHT300 speakers problem.. I don´t know what´s happen, probably some speakers connections are not working or the system require a reset...please help me with this. Thank´s.
