Hello, sir i have a Kingston 4GB Pendrive.I had run a program "LOCKv116.exe" on my pendrive and set password on it, but now after inserting pendrive to my pc, it is detected but when open it this message appears "please insert a disk into drive G:" If try to format it message is "There is no disk in drive G:"..If I run the program LOCKv16.exe it shows a message "please insert the device or run this utility as previledged user."
my ID [email protected]
SOURCE: kingston pen drive locked by LOCKv116.exe
I want lock my pen drive by password.
Thanks & Regards
Sandeep
SOURCE: LOCKV116
hello, i have a Kingston 2GB Pendrive.I had run a program "LOCKv116.exe" on my pendrive and set password on it, but now after inserting pendrive to my pc, it is detected but when open it this message appears "please insert a disk into drive G:" If try to format it message is "There is no disk in drive G:"..If I run the program LOCKv16.exe it shows a message "please insert the device or run this utility as previledged user."
SOURCE: pendrive problem
opening pen drive, it shows 'please insert the disk' & it shows 0 bytes & while trying to format it shows the same message again , i am using 2 gb pendrive of trancend.
SOURCE: Non recognized Kingston pendrive 4 Gb
i bought a kingston 2 GB pen drive. computer does not recognize. device manager says drivers are not installed. but it works in safe mode. kindly help
SOURCE: Can't view file in Kingston 8GB Pendrive.
Try this,
Format the drive using HP disc format tool after backing up the data.
Make sure you select FAT32 as file system.
You can download this tool from the following link,
http://www.eocfiles.com/bdc86eb1ed2989c30dcd1902e84939ae/bootdisks/SP27608.exe
Please let me know if the issue persists.
