SOURCE: Durabrand Dur 7 dvd player
simply take the unit to Radio Shack and ask the peeps there to hook you up. They have almost any type of plug for almost any type of adapter. Good Luck
SOURCE: DUR-7 portable dvd player battery life?
Wal-mart does sell replacement batteries. http://www.walmart.com/catalog/product.do?product_id=2350787 For this particular unit. However; in the future I would suggest researching a particular item before buying esp from Wal-mart. As Durabrand doesn't even have a website.
SOURCE: Durabrand DUR-7 portable DVD player
Most DVD players that would display such a message even with a known good disc inside signifies that the that the laser eye/lens is not reading the disc. This could probably be attributed to:
1. dirty, damaged, inverted, blank, un-finalized burned CDs or DVDs;
2. defective, weak burned-out laser eye/lens;
3. defective slider shafting (where the laser eye's carriage moves.
A few things you can try:
1. Use a CD cleaner (readily available from most computer shops);
2. use a can of compressed air and blow through the inside of the loaded disc area;
3. gently tap on the top cover where you estimate the reading/laser eye/lens would be;
4. gently press on the tray door once the disc is loaded.
Should
this not be corrective, perhaps your best bet would be to seek the services of a qualified professional such as those in a Service Center. Alternately, your friendly neighborhood electronic shop should do just fine.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kindest regards.
SOURCE: battery charger
click on hyperlink:
buy replacement ac power charger adapter Durabrand DUR7 DUR-7
SOURCE: I am looking for the car charger (DC 9V 1.5A) for
You can buy a new car adapter by clicking on the hyperlink:
buy replacement car adapter power charger cord for Durabrand DUR7 DUR-7
