To changethe Region code on your DVD player, open Control Panel - System - Hardware -Device manager, and click on DVD/CD ROM drives, then right click on the DVDdrive and click Properties then click on DVD Region.
You can enter a new region and it also shows you how many changes have beenmade.
NOTE you can make only 4 changes and the player will lock permanently on the4th change. Region 4 = Australia
If you want to play DVDs from any region you maybe able to upgrade the firmwareto make it region free BUT if you make a mistake or installed the wrongfirmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece ofsoftware (Passkey for DVD) that allows you to play DVDs from any region andPasskey for Blu-ray that allows you to play Blu-rays from any region. There areseveral available on the Internet but my favourite is DVD-Region Free From: -
www.dvdfab.com/products,free.htm
You can't play a DVD on a dvd player that is not with the same region code support. But you can use some DVD copy tools to get a DVD copy without DVD region code so that you can play it on your dvd player. You could try Leawo DVD Copy which can copy dvd at high speed.
I think you need a similar software:
http://www.dvd-rip-software.com/dvd-software/3herosoft-DVD-Ripper-Platinum-Suite.html
SOURCE: Just moved to Australia from
Try to follow this instruction it may help:
Look for your DVD hack player. There are many sites that provide feature DVD hacks there are two popular site DVD exploder and video help simply locate the model number of your dvd and check if there is a hack.Enter the code using your DVD remote control and before entering the code be sure that the tray is open then follow the instruction exactly when inputing the codes.
