SOURCE: RESTRICTION CODES
hi if you tell me what county and network the phones locked to and also the imei number i can give you the unlock code but i need this info so i can use the software to generate the unlock code
SOURCE: my phone is restricted
If your Nokia phone gives you a message saying "RESTRICTED", shut down your phone, remove the simcard, power on phone and perform the "CODE ENTRY" instructions below.
-If your phone doesn't say "RESTRICTED", make sure your phone has a simcard from any other provider (other the the one the phone is locked to) and perform the "CODE ENTRY" instructions below.
-If you entered a bad code too many times and get the error "NOT ALLOWED", then your counter is blocked and only a cable method will unlock your phone (If the code above does not work the 1st time do not keep trying it as you only have 3 tries).
CODE ENTRY INSTRUCTIONS
-You will received a code that looks something like this: #pw+454545454567715+1#
-Every digit, symbol, number and letter that you receieved must be entered without any spaces. Follow the directions below to find put how to get the # p w and +
P appears after pressing 3 times the button ( * )
W appears after pressing 4 times the button ( * )
+ appears after pressing 2 times the button ( * )
- after entering your unlock code the phone should show "SIM Restriction Off". Youg Nokia is now unlocked.
SOURCE: phone restricted
Try this code. I have a Nokia Master Code calculator, it shows me the unlocked code for when you lock your phone and forgot the code, but give it a try, who knows. 1066541060 I hope it works.
Testimonial: "CODE IS NOT MATCH INVALID CODE SIR PLS CODE IS MALE MY PHON IS NOT WORKINK I AM HANDICAM"
SOURCE: nokia 3500c phone restricted undo
Try with this code, *#7328748263373738#, this is the security reset code for Nokia, you need to type this on the screen menu. If this doesn't work with your phone, try using these two codes with the same method *#7370# or *#7780# but you should keep in mind that all your settings including your phone contacts, sms, etc will be erased. So be prepared before you do this. Good luck..
