Question about Kodak ESP 7250 All-in-One InkJet Printer
Kodak 7250 print head jam
The print head is stuck all the way to the left of the printer. It grinds trying to release it but can't. nothing is blocking it, i've tried to release it but don't want to break it. I can't test to make sure cartridges are in correctly becoase they are positioned under a piece of the printer [on the left].
    New Friend:
  • 3 Answers
This problem has plagued me for a very long time. The issue is that the printer head is "glued" in the resting position under the guard of the printer, so you can't remove the ink cartridges to clean it. Solution is to (I know this sounds stupid, but it works) turn the printer on the side where the printer cartridges are (if they are stuck on the left side, turn the printer on its side so the cartridges are on the bottom). Turn the printer on, and the cartridges magically start moving! I guess there are some sensors that get tricked out when you tip the printer on its side. If the cartridges are still stuck, click the "ok" button, and before it gets a chance to see if you actually fixed the problem, turn the printer off using the power button. It takes a long time, but you should see the ink trap lower (release the ink cartridges) and the ink cartridges start moving to prepare for shutdown! Grab the cartridges when they move out of their hiding place and don't let them go back until you clean the print head so it doesn't get stuck again. Remove the ink cartridges, then push the grey tab to release the print head. Wipe the bottom of the print head clean with rubbing alcohol (it will have a lot of gooey - sticky ink stuck on the bottom). I used nail polish remover since I didn't have rubbing alcohol available. You can also wipe down the ink pad which is where the ink cartridges were previously jammed to clean up more of the mess and prevent this sort of thing happening again too soon. Good luck!
Posted on Jan 03, 2014
  • Lyle Fort
    Lyle Fort Jan 03, 2014
  • Carol Prettyman
    Carol Prettyman Aug 23, 2018
    that didnt work for me.
Anonymous
SOURCE:
Anonymous
  • 3 Answers
SOURCE: Kodak printer dock cartridge is stuck inside printer dock
turn off your printer. Press and hold down the left arrow and the transfer button, turn on printer while holding them down, you should hear your printer make some noises, This will be the head lining up. Open the side door to gain access to the cartridge, push on it to see that it i s"locked" in. Lift up on the Green release button on the inside and your cartridge should come free on its own. Be careful not to try and pry it out for this can void your warranty! http://www.wonderhowto.com/how-to/video/how-to-remove-a-stuck-cartridge-on-a-kodak-g600-printer-dock-249276/view/
Posted on May 18, 2009
Anonymous
SOURCE: Kodak Easyshare G600 printer dock problem!
I HAD THE SAME PROBLEM. tALKED WITH THE KODAK TECH LINE AND THEY TOLD ME TO...TURN OFF PRINTER, HOLD TRANSFER BUTTON AND LEFT ARROW DOWN AT THE SAME TIME AND TURN THE PRINTER ON. DO THIS THREE TIMES. iT WORKED FOR ME. GIVE IT A TRY.
Posted on Nov 27, 2008
Anonymous
  • 16 Answers
SOURCE: My Kodak will not print any color beside blue
Call Kodak and ask for a solution. Most likely they will give you a new print head and cartridge.
Posted on Apr 26, 2009
colin butcher
  • 518 Answers
SOURCE: Kodak esp 3 all in one. colour prints come with purple tint
Surely you can turn the flow of ink down via your settings
Posted on Jun 14, 2009
HARSH BAWA
  • 295 Answers
SOURCE: kodak printer esp.3 ...paper jammed
u should only use kodak inkjet papers with size plain paper, coated paper, photo paper, iron-on, transparency film, label media, greeting cards, 20 to 24 lb. plain paper. open back access door of printer by pulling out the latch on back of printer. remove paper-jam from the rollers. u can find manual for ur printer onwww.kodak.com/go/manuals.
Posted on Jul 28, 2009
Canon mx860 printer not using ink from PGBK 220
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Mar 07, 2013 | Canon PIXMA MX860 All-In-One InkJet...
MFC-J435w when trying to print I get error 5A Help?????
buy a new one. there is no repair for print heads. and don't use refill inks.
not good for print heads
Aug 01, 2017 | Brother MFC-465CN InkJet Printer
HP Officejet 6500A - frequent print head clogs
INK PROBLEM
Dec 13, 2012 | HP Officejet 6500A Plus
I have the Epson Stylus Pro 3880. Up till a few weeks ago all was well, the today, it decided not to print out the black areas of my shots. I've check the inks, the heads all is well. HELP
Dec 02, 2012 | Epson Stylus Pro 3880 InkJet Plotter...
White lines on dark photo prints
White lines means some of the print head nozzles maybe blocked.
Try the deep clean print head cycles then do a test print. If this still does not fix the problem then a new print head is required.
Print heads are expensive and if your printer is old then maybe better to put your money towards a new printer.
Oct 18, 2012 | Canon MP560 All-In-One InkJet Printer
Printer won't print in colour, keeps saying recalibration needed
Blocked print head nozzles
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required. Also try - Removing the print head, run it under hot water for 2 mins, then let soak for 10 min. then used a can of compressed air to dry thoroughly. It may fix the blocked nozzles.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Sep 24, 2012 | Kodak ESP 7250 All-in-One InkJet Printer
Hp colour laserjet 9500hdn has service error 49. FF81
I've seen this exact error a few times on the 4101s & turned out to be a bad EIO hard drive.If you replace the drive, you'll most likely have to download the newest firmware & load it to get every feature back.
You can try & initialize the drive first though:
- Turn off printer
- Press & hold [Start] button
- Turn printer on, wait for all 3 LEDs to stay solid then release button
- Press & release [Left] arrow button (should read "Initialize Disks" on display
- Press & release [Select], then wait for printer to warm up
Listen also to the drive & if you hear it clicking over & over then it's bad & will need replaced.
Apr 29, 2012 | HP Color LaserJet 9500HDN Printer
Can I remove & clean the print head on an Epson printer?
i've tried to remove it from the sliders and to have it soaked in alcohol for about 10 hours without any luck. It is too much work without any guarantee. I suggest to junk it and get a new one (if possible with heads on the cartridges so they are replaced with each refill)
Mar 09, 2012 | Office Equipment & Supplies
Error Code: 07,010.43:1944
You are doing nothing wrong.
That code means your print head is not moving into position properly, AKA to slow in pivoting back and forward.
Here are the problems in order of likelyhood.
1. The print head pivot block. When, from the front, you take the left side cover off, about half way back on the lower part of the frame there is a stainless steel block, about 1 inch by one inch square. Most of the time what happens is some ink has seeped into that block and the pivoting of the print head is very slow. What you want to do is remove the spring assembly over that block. It just pulls back and you latch it up and to the left. Remove that block and soak it in very hot water. That softens the contaminating ink for easier removal. Clean the block thoroughly and as best you can pick out the remaining ink surrounding it in the frame of the machine. Lightly lubricate the block with a silicon of very highly refidned oil. I stress lightly.
2. The cleaning blade has stuck to the print head. That normally is caused by not powering down the printer properly or a power failure shutting it down. For that, you have to remove the right and left side covers, and the ink loader,( where you put the ink sticks). That is just held in with pressure tabs. Remove the ink loader then look between the drum and print head, if the wiper is stuck there, gently pry it loose from the print head, and run 2 or 3 cleaning cycles.
3. While you would have the ink loader out, if the wiper isnt stuck, make sure one of the cables to the print head are not holding it back.
One of those 3 will resolve the problem. It is caused by the print head not being able to move freely.
Mar 23, 2008 | Xerox Phaser 8400 Laser Printer
Kodak ESP 7250 All-in-One InkJet Printer Logo
2,474 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Ekse
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
