I put in a load of towels on the cotton cycle, The machine started, buzzed a few times and then the FL code appeared. After that, I looked up the code, took out half of a small load of towels and tried again with the same results.
This is a Failed to Lock Code. Check the seal at the lock to see if something is in the way or blocking it. Overloading or having too many clothes in the way will also cause the door to fail to seat correctly. Generally however the lock mechanism needs to be replaced or reseated as it is no longer making contact with the control board.
Hello keisha, thank you for your post!
I understand that your Frigidaire washer is making a buzzing sound until the cancel or start button has been pushed. It sounds like it could be a possible issue within the door either not being fully closed or it could be a defective switch. I would recommend resetting your appliance which can be done by disconnecting power to the appliance for roughly ten minutes. Please comment back if that did not help correct the issue. -Matt
