The TV won't turn on. It is plugged in, but won't turn on at all. Is it fused?
It has a fuse and if the power light comes on and blinks a specific code that would be a error code.
This set weighs close to two hundred pounds, follow the power cord inside the set as it goes almost directly to the fuse which should be a 6.3 amp fuse----careful if its bad, it is a slow blow and special, a Radio Shack or Generic one the same amperage and type will blow for no reason, if its bad don't keep feeding it fuses.
my tv power light is red and i push power button but light stays red wont turn blue. and nothing comes on
was working fine tried hooking up laptop said no signal then tv shut off i unplugged it for like 20 mins and stiil the same.
