Question: FAGOR FE-1158 ELEGANCE WASH MACHINE
We have a 5 yrs old FAGOR FE-1158 ELEGANCE wash machine w/o problems till now. We have a problem with the centrifuge program-it does not start, although the machine can spin slowly.
Is it a motor problem or a problem with the programmer?
Thanx for the help in advance!
  • Anonymous Mar 16, 2014
    clasixx 5
We have a 1 yr old Bosch wash machine w/o problems till now. We have a problem with the centrifuge program-it does not start, although the machine can spin slowly. Is it a motor problem or a problem with the programmer? Thanx for the help in advance!
Posted on Nov 13, 2008
    New Friend:
Ich habe die Waschmaschine FAGOR FE-1158 schon 7 Jare.Jetzt wenn voll beladen bei wasche stoppen und schlecht Wasser komt.
Ich bedanke vorher!
Mfg
30655 Hannover
Posted on May 31, 2010
6ya staff
SOURCE:
Fagor fe 536 does not spin in max speed
Belt is worn. Replace belt. GOOD LUCK FRIEND.
Jan 12, 2015 | Fagor Washing Machines
Fagor fe 948
GOOGLE: fagor fe 948 manuel. lol. its out there to be downloaded.
May 21, 2014 | Washing Machines
Why my Fagor FE 536 washing machine is not draining?
One of three things is likely happening. 1) The drain could be clogged or kinked or 2) The water pump could be failing or 3) The belt that runs the pump is slipping or broken.
Sep 20, 2012 | Refrigerators
Fagor select fe-1046 manual
Does anyone have a manual or know where i can find a manual for a Fagor Select FU-1046 washing machine
May 17, 2012 | Washing Machines
I do not know how to use fagor elegance:FE-S-1148.can you send me a guide?thx
Sorry but FixYa cannot do that direct- members of the forum are just people from all over the world, probably working from home, and not representing any particular manufacturer ;-0)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Aug 20, 2011 | Washing Machines
Fagor Elegance FE 538 washing machine. A copy of operating manual pl.
i dont know how to use that machine.. FAGOR Elegant FE-538 ..
neet guide or manual ....
Jun 15, 2011 | Washing Machines
We have a fagor washing machine (model - FU-1148-IT) and cannot find a user manual for it anywhere, please help as we have a baby and it's not cleaning his clothes on the setting we are using
Have it on Number 3 for the wash, 5 is the best spin. It gets smelly quite quickly, so wash the drawer alot, and get the mould out from ALL the inside of teh drawer compartment, and wash it at 90 with washing machine service powder (Asda 3.50!)
Nov 26, 2010 | Fagor Washing Machines
"FE" error code; won't stop filling
Hello Sheri Tucker,
The "FE" code is referring to a bad or malfunctioning water valve. The machine continues to fill because the solenoid on the valve inside the machine isn't closing to stop the water. The valve should be inspected and/or replaced if bad. This will require some dis-assembly, if washing machine repair isn't something your comfortable with then a service call is the best bet. If you are going to try and inspect yourself please make sure you unplug the machine before starting any dis-assembly. Hope this helps.
Thanks,
edgin96
I’m happy to assist further over the phone at https://www.6ya.com/expert/ryan_7b238a1b08d97b98
May 19, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
1,985 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
