SOURCE: dewalt dc 988 cordless drill
posible motor problem, the built in magnetic ring in the motor may broken inside or just to much dust in it. advice when replacing motor also replace th switch for the cost $132.00 plus tax canadian. thanx
SOURCE: looking for repair manual for Dewalt DW87 cordless drill
Go to Dewaltservicenet.com and type in your model number in the middle of the page at the bottom. From there you should be able to download a schematic and some of the parts are component parts and don't have a lot of replacement items. It sounds like you broke the clutch or gearcase and both are components.
SOURCE: dewalt 18 volt cordless drill
Use a pipe wrench on it to give yourself a little more leverage. It is simply jammed all the way open and it will release when you apply enough force.
SOURCE: How can I disassemble a Dewalt keyless cordless
depending on the chuck it would take special fixtures to press apart, and unless you are very good with tools you would damage it beyond repair. I have never taken a keyless apart and tried to repair and put together, I have on the other hand done the same with the keyed chucks.
Testimonial: "I also have taken appart keyed chucks. Thats why I am thinking there might be a way for the keyless. Thanks for the post."
SOURCE: I have a DeWalt DW927 cordless drill. It's lost
the brush assembly slides out of the back of the motor. I suggest going to Dewaltservicenet.com and downloading a breakdown for this tool before starting. I don't think that the brushes are going to be your only problem though.
