Wireless wrt54gs x 7.5 has lost internal power, I can fix it if I can pinpoint the bad component. trouble shooting with My meter indicates the component that the source plugs into has an opening. I would like to know part # and if it has some type of circuit protection in the component itself? Ricky L
SOURCE: some light on; some not
disconnect power supply from the router, wait for 30 seconds , and reconnet it back then check you get the power light.. if not try in a different power outlet..check the physical connection, the modem should be connected to internet slot in the router ,so that you would find the internet light lit up.., if still you do ont see the power light or the wlan light, reset your router, if you look at the back of your router, you would find a reset button, press and hold the reset button , with a pen on paper clip for 30 seconds with the power cable connected and disconnectc power and reconnect and then check..if still not the problem is with your router
You can see the SSID name from one of your wireless computer that is already connected to the wireless network. Just point your name over the wireless little computer icon down at bottom right hand by the time. It will say there "Wireless Network Connection, Connected to "name of the network". That "name of the network" is the wireless signal name like "Linksys" or whatever name you gave to your network when you setup the router. That's the SSID name as well. Wireless Network Name = SSID.
SOURCE: Need to know voltage needed for wrt54g Linksys wireless router
The stats on my adapter are as follows:
.5V 2.0A
SOURCE: lost my linskys wireless-g wrt54gs cd installer
you can setup the router manually without the CD.
1> plug a network cable into the router, and your computer
2> type the following into your web browser http://192.168.1.1
3> enter your settings for your ISP
4> choose your wireless settings (it is recomended to setup some security on your network so people can't have access to your network without authorization)
SOURCE: WRT54G keeps disconnecting itself, requires
Go to Administrative Page on your router at section Setup - Basic and activate: Keep Alive : Redial Period 30 seconds.
After that restart your router
This is High Quality original LINKSYS AC Adapter Charger
Input Voltage: 100V-240VAC (50-60Hz)
Output Voltage: 12v1a
Model: AD12V/1A-SW
DC Plus Dimension: 5.0mmX2.1mm
Compatible Models:
WAG300N
WRT54G
WRT54GS
WRT300N
Linksys Routers
