It takes in water but then shuts off and errors again.
This is a problem with the signal from the water heating element "Thermistor" a Thermistor is a solid state sensor that senses temperature, in this case water temp. The Thermistor is part of the washers water heating assembly and not sold separately from it. There is a factory repair bulletin associated with the problem and the new part has improved reliability. I can't understand what the Maytag folks you called would tell you it is not listed, it is a common fault in the Neptune. Please rate my help. Thanks
Testimonial: "Thank you for your help. Customer service at Maytag seems far more interested in scheduling a maintenance call than helping."
Check the manual: http://downloadfreemanuals.com/maytag-neptune-washer-manual/
SOURCE: My Maytag Neptune 7500 front load washer will not turn on when the AC or heat is running
Check voltages at the outlet. My guess is that you are on the HVAC circuit, and the Neptune is more sensitive than your hvac equipment. Also check that the neutral is about the same potential as the ground.
SOURCE: maytag neptune MAH 9700 AWW - error code nd
you need to remove the front cover by removing th escrews holding on the door hinge nad 2 other screws oppisite the hinge, after taking off screws the front "u" shaped panel will pull foward and off( hoeld on by 2 clips along the bottom. the drain pump is located right back corner of machine..ill assume that the machine is still full of water so youll need ot **** out as much as possible before removing the hose connected to the pump. theris going to be some water no matter how much you remove nut might as well get as much as you can. youll either find debris in hose, or debris lodged in imoeller of pump, even seen coins standing in the plastic hosing preventing flow of water.VERY< VERY rarely bad pump ussually just a clog.IMPORTANT UNPLUG UNIT FIRST LOTS OF LIVE WIRES UNDER HERE
SOURCE: maytag Neptune MAH 8700 AWW
NF - No Fill
It means that the Washer does not turn on water valves to fill washer with water.
Try the following steps and the problem should be solved.
1.Is the water turned on?
2.Check inlet hose screens for restriction.
3.Check wire connections in harness leading from machine control board to pressure switch.
4.Check water valve.
5.Check inputs and outputs at machine control board.
Good luck.And please do rate my answer.Thank you.
SOURCE: On my Maytag Neptune MAH-3, the water is running non-stop
check plastic hose out side of tub to pressure switch
if ok replace pressure switch
contact Maytag ServicesSM, Maytag Customer Assistance: U.S.A. 1-800-688-9900 or
Canada 1-800-688-2002.
Contact the repairclinic.com for help, they are an online parts site. Sears Direct also has a great website with exploded views of the washer to air in a self help repair. Both offer parts at reduced cost. I am just passing on the info, have no connection to either website.
Thank you so much. Your help is very appreciated.
I have another question....We tested the thermistor, unplugged the connections at both ends of the loom and greased them...still errors out. We noticed that the control knob feels really sloppy and if you just touch it the warning beep sounds and the tE error code flashes. My husband bypassed the thermistor and we still get the tE code. Is it possible the electronic control board is causing this? Thank you
Yes experiencing the same problem..was wondering if there is a weight sensor on the drum which has weakness...
