Qvc blocked this was a app bundle. When tablet was replaced by co. Now i cant dewnload the apps.
SOURCE: Just got my tablet and
Comment if you need more help and please rate a 4 if this was helpful
Thanks!
SOURCE: Cannot access Appslib app library
I couldn't either! So, I uninstalled the appslib and reinstalled it and it works great now! You have to reset everything and you will lose apps I guess if you have any, I had none so this didn't affect me. If you go to Coby's website and under FAQ's it explains how to uninstall and install. Good luck!
SOURCE: my apps libaray on my
Sounds like you need to reset AppsLib.
This fix will wipe all your data, so be sure to back everything up.
Go to Settings.
In settings go to Go to "Privacy".
Select Factory Reset.
Select Reset Device.
Connect the unit to the computer using the USB cable and "Select" Erase
Everything"
The following will occur:
• The screen will display COBY
• The screen will display Android
• The unit will reboot to the Menu screen
Step 6- The unit will prompt to calibrate. Hold stylus on the center of the target.
Repeat as the target moves around on the screen. ****DO NOT *** press Return or Home".
The unit will display "calibrate success" and will return to the main /home menu automatically. If for any reason the unit went into standby mode and the touch screen does not respond, reset the unit using a pin.
After the Factory Data Reset, do not launch the Applibs yet until:
1- You have configured your Wi-Fi
2- Check/enable "Unknown Sources"- Go to Settings, Application Setting. Done.
You can now open appslib.
SOURCE: operating system,xp tablet edtion
I can get you a copy of the 2005 xp tablet edition os, you would have to use your own cd key and activation to make it legal. Although it will install with it's own cd key, licensing requires you to use legal activation and the key that came with your unit. Check with mpcdrivers.com
SOURCE: How do i copy .apk apps from my computer to my
Just use the provided USB cable and connect the tablet to PC. Windows will recognize it as another drive (USB Mass Storage similar as USB HDDs and USB sticks). Copy the APK file anywhere (for example to Downloads folder. Then unplug from PC and run the Files application on Archos. Browse to the directory and clicking on the APK filewill start installation process.
Testimonial: "Thanks, was easy to figure out compared to my friends Kyros. Even got that GAppsInstaller .apk installed..."
