Panasonic Lumix DMC-TZ1 Digital Camera Logo
Tiffany Reitz Posted on Oct 17, 2008
How do you set a date stamp on this camera? I want the date to be displayed on every picture. Not a travel date I have to keep setting every time I travel.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 09, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
782
Points
1helpful
How do you set the cannn 500d to date stamp pictures that you view
If you want to see the date /time info while viewing the pictures on the camera, you can change the display settings, press the DISP button, till you see a smaller picture and the date and time on the bottom of the screen.
If you want the date and time printed on a picture, you should use the pict bridge option from the camera and in the setup you should chose the setting for that. See page 165 and following from the manual.
But the simple timestamps of the yellow or orange stamps like in the older digital cameras, won't work.
Because the camera keeps a all information stored in the EXEF part of the picture, it won't destroy the jpeg it produces. If you really want the date and time imprinted, you should use a program on the computer, to use the date and or time info and brand it in the picture, before saving it.
Be aware all pictures do have the date and time info in them and most viewers on the computer (whatever OS) will show the info when asked, anyway.
Sep 08, 2014 • Cameras
2helpful
2answers
How do I display date/time stamp on samsung s760
Power on camera
Press "menu" button (center button)
Scroll across to setup menu (the cog and wrench icon)
Scroll Down to Imprint
You can choose Off, Date, or Date&Time
Make your selection
Press OK/Set (center button)
This Should have activated Date and time stamp
For more information you can read the SAMSUNG manual here:
http://downloadcenter.samsung.com/content/UM/200902/20090202162312203/S860_760_English.pdf
PAGE 47 shows you how to do this also
PAGE 44 Shows you how to set the correct time
Hope that helped
1helpful
I want Date & time stamp on pictures
Hello and Welcome
To set the date and time stamp on pictures, Follow the given instructions:
  • Power on the FUJIFILM FinePix J28 digital camera and wait for the hardware to finish running through its start mode
  • Press the "Menu" button on the rear of the device, then choose "Setup."
  • Select "Options," followed by "Date." This brings up the date display. The display blinks as it has not yet been set.
  • Push the top button on the control display to advance the first number in the date. Once you have the correct number selected press "Enter" and repeat the process for all the numbers. When the date is set the time information appears. Follow the same procedure to set the time. Press "Enter" to accept the changes. Now every picture captured with the FUJIFILM FinePix J28 will save the date and time to the pictures
For further assistance, I am here to help.
Thanks and Keep Visiting FixYa
2answers
I want my pictures has the date on them when i downloaded to my computer. How to set this function? Sorry for my bad english.
Press [MENU/SET]. Press up/down to select [CLOCK SET]. Press up and down to set time. Under Appearence set date, time and the display order for the date and time. Press [MENU/SET] to close the menu.
You can read more about this in the user manual, page 19: http://panasonic.com.au/content/library/files/F002107.pdf
How do I date- stamp photos with my camera?
Enable the travel date option from Menu->Setup->Travel date. There are two options. SET and OFF. Choose set and exit the menu. Every picture you take from now on will display the date on which it was taken.
2helpful
2answers
Manual too difficult
It seems to me, after reading the Operating Instructions, that it's not possible to stamp the photos automatically while taking them (EXCEPT for when stamping TRAVEL DATES - see below).
What you can do is enter the Play mode, the stamp the photos manually- 1 to 50 photos at a time.
To do this, kindly look on pages 66-67 for detailed instructions (with illustrating images).
Be sure to set the correct time and date prior to stamping the photos. Look on page 16 for further instructions.
If you're taking pictures during traveling, you can set TRAVEL DATE, which will also have a reference to the day number of your travel (page 48).
Hope you'll find my information useful...
Good luck,
Pelu.
28helpful
2answers
How to set date stamp for canon ixus 860is
The date and time can be included on the pictures taken only with the camera in postcard mode. You must also activate the date stamp option in the menu.
To set the camera into postcard mode, press the [Func.] button on the camera, then use the [arrow down] key to go down to the last option in the menu, and there you can choose the [Postcard mode]. Press [Func.] again to exit the function menu.
dsc_include_date01_tcm13-520510.jpgTo set the date and time stamp, press the [Menu] button and then use the [arrow down] button to go to the [Date stamp] option in the menu. You can set this to "Date" or "Date & Time". Press the [Menu] button again to exit the menu.
dsc_include_date02_tcm13-520511.jpgBe aware that if you take pictures with this option enabled, the Date and Time cannot be removed from the pictures at a further time. It will permanently appear on the picture.
Please rate my help++++Thanks for using FIXYA
1helpful
Time and date display
I have the same camera and the only way to do this is to first, Make sure you have set the date and time correctly on your camera. Take a picture or View picture you want date & time stamped. Press the circular 'Menu/Set' button Press down arrow to playback mode Press right arrow on 'text stamp' Choose whether to apply stamp to single or multiple photos Press 'Menu/set' to select photo to stamp. Choose which stamps to add. Date, time, age etc.. Press 'Menu/set' again and select 'Yes' in box. The only problem with this is that it will resize your photos to 3m, which can make them grainier if you took them at a higher res. Gillian
2helpful
2answers
How to make date stamp option ON in Canon IXUS70 Model
Hi there, my name is Rob and I can help you.
To put the date stamp in a picture do this:
1) Make sure you have the correct date and time set in the camera. To do this:
Push the function/set button. Press the directional button down to select Date and Time.
Push the directional button to the right then down or up to set the date and time. Then press the function/set button to save it.
Then:
2) Push the selector button up to the camera icon, and press function/set. Scroll down to Date Stamp.
Scroll right to turn on the Date and Time Stamp, then up or down to until it says On.
Press function/set when your done.
That is your solution. Remember once the date/time stamp is embedded in a picture, you can't take it out.
Let me know if you have any further questions, and thanks for coming to FixYa. Please feel free to rate my solution a fixya.
Rob
9helpful
2answers
TZ 5 not TZ50! Date stamp.
I have the same camera and the only way to do this is to first, Make sure you have set the date and time correctly on your camera. Take a picture or, view picture you want date & time stamped. Press the circular 'Menu/Set' button. Press down arrow to playback mode. Press right arrow on 'text stamp'. Choose whether to apply stamp to single or multiple photos. Press 'Menu/set' to select photo to stamp. Choose which stamps to add. Date, time, age etc.. Press 'Menu/set' again and select 'Yes' in box. The only problem with this is that it will resize your photos to 3m, which can make them grainier if you took them at a higher res. Gillian
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
