SOURCE: error list
Unforuntately, it looks like the vendor wants you to go through a registered dealer for service. http://www.usa.canon.com/opd/controller?act=OPDSupportDetailAct&fcategoryid=2275&modelid=9717 The only downloads available are drivers. http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2275&modelid=9717
SOURCE: ihave problem with canon ir 600 .Error show E677
E677 communication error between machine & pc.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
SOURCE: canon IR 2020 showing system Error E007 printer
my canon ir2020 is displaying system error E007
SOURCE: canon ir 600 error e537
E537
The front aligning plate does not reach home position when the front align-ing motor (M3) is driven for a specific time.
The front aligning plate does not leave home position when the front align-ment motor (M3) is driven for a specific time.
Possible causeThe front alignment motor (M3) is faulty.
The front aligning plate home po-sition sensor (S6) is faulty.
The sensor connector is disconnected or has anopen circuit.
The front alignment motor relay harness if faulty.
The frontaligning plate is subjected to an abnormal load.
The finisher controller PCBis faulty.
Remedy1)Front aligning plate home position sensor (S6)Check the front aligning plate home position sensor (S6).
Is the sen-sor normal?NO:Replace the sensor.
2)wiringIs the wiring between the finisher controller PCB and the frontalignment motor (M3) normal?
NO:Correct the wiring.
3)Front aligning plateIs the rack riding over the collar of the roll?YES:Correct it.
