I require a instrution manual
SOURCE: The back roler is making a very loud vibrating
Best way to check the roller to see if the bearings have failed is using a long shafted flat tip screw driver and place it on the end on the adjusting bolt. Then put your ear on the handle and listen, if the sound has amplified then the roller is defective and needs replacing. If not then check the front roller the same way because sound travels thru the frame and the problem maybe originating their. Call Icon Fitness to order part their is 1-800-999-3756.
Testimonial: "thank you very much. I took it to pieces and fixed myself"
