DRIVE IS ALWAYS ENGAGED IN FORWARD MOTION,,,CREEPING FORWARD,,NEED ADJUSTMENT,PROCEEDURE ON..WHEEL CLUTCH ASSEMBLY..
SOURCE: Need repair manual for Toshiba P105-s6024 Laptop
Here is just what you ordered. Hope this helps. Just take your time and have patience. Not very hard. Good luck and have a good day.
http://www.irisvista.com/tech/laptops/toshiba-satellite-p105/take-apart-1.htm
SOURCE: When I back my foot off the brake to slowly engage
The gear lever...move it to the forward position only slightly....not all the way forward...it'll move slower...
give it a try... worked on mine yesterday.
K
SOURCE: engine running--when i engage parking brake it
your brake pads are probably spent or you need to adjust them....usualy behind the rear passanger tire...lol
turn the nut clockwise justa half turn...put the tire on and try again...this prosses is very painstaking because most of these machines its hard getting to this nut with the tire on
SOURCE: craftsman 42 in 19.5 unable to control speed forward motion
is this perhaps a hydro trans? if so, try putting the shift lever in neutral, then let off the brake pedal, use the shift lever to go forward and to neutral to stop - same with reverse, don't even use the brake pedal except for emergency stops. if it's a manual shift, it's possible the belt is incorrect, and/or the belt guides are bent or the belt is improperly routed - the belt guides are important as they allow the belt to "blossom" off the engine pulley, reducing the "shock" load when engaged - hope this helps
