Nokia Bluetooth Headset BH105 Logo
sobin sebastian Posted on Jan 26, 2012
Nokia bluetooth head set BH-105 can't conect with my nokia C6 mobile
Actualy my nokia bluetooth headset BH-105 cant cant pairing with my NOKIA C6
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Feb 10, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1388
Points
11
1: SWITCH ON THE BLUETOOTH FUNCTION ON YOUR MOBILE 2: THEN CHANGE MY PHOES VISIBLITY FROM HIDDEN TO SHOWN TO ALL 3; MAKE SURE U HAVE PRESSED THE BLUETOOTH HEADSET SWITCH ON BUTTON FOR AT LEAST 10 SECONDS . 3: U WILL HEAR A BEEP SOUND WHEN THE HEADSET IS SEARCHING FOR PAIRING 4 NOW SEARCH FOR NEW DEVICES ON YOUR MOBILE 5 WHEN THE SEARCH COMPLETES IT WILL SHOW BH-105 6 : SELECT IT AND CLICK PAIR . FINISHED
5 Related Answers
Anonymous
  • Posted on Feb 20, 2009
SOURCE: Pairing NOkia BH-207 with Blackberry 8120
Power it off
Press the power on button for at least 10 seconds, until it keep the blue ligth on and then pair it with your BB
Anonymous
  • 123 Answers
  • Posted on Aug 10, 2010
SOURCE: how to use nokia bluetooth
This is the instruction manual that will tell you how everything on your headset works....MANUAL
Anonymous
  • 1932 Answers
  • Posted on Aug 31, 2010
SOURCE: How to pair up nokia bluetooth headset BH-213 with
Hi
1.Ensure that your phone is on and the headset is off. 2. Press and hold the multifunction key (for about 5 seconds) until the green indicator light starts to flash quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. When the headset is connected to your phone and is ready for use, the green indicator light flashes slowly.
thank You
Anonymous
  • Posted on Sep 16, 2010
SOURCE: trying to pair nokia x6 with nokia BH-214
The BH-214 manual (available to download from Nokia's website) gives 0000 as the code (if you are prompted - I did this today on an X6 without being promoted for the code!).
Mike.
Testimonial: "thankyou that worked "
Anonymous
  • Posted on Jan 08, 2011
SOURCE: Bh-105 bluetooth headset not pairing
U must RESET the Headset.
Switch OFF the Headset.
HOLD the answer/end key + power key (for about 5 second).
Red + Green indicators lights start to alternate.
Then Ur Headset is RESET.
Connect / Pair it as normal.
2helpful
2answers
I cannot pair my blackberry curve 3G with my Wireless Nokia headset BH-503! It was working until I paired it with another nokia 2700 and after trying to pair it with my blackberry curve 3G again, it...
It is paired with the Nokia 2700.
From the manual (Click here to get it) page 11;
To clear the pairing and volume settings, switch off the headset and press and hold the multifunction key and press the volume up key until the indicator light alternates red, green and blue three times.
3helpful
2answers
I have made connection between nokia BH-503 and my laptop operating windows 7. But after that when i am trying to connect with my nokia x3 mobile and BH-503 the mobile do not able to find the head set.
Try manual connecting. If you have paired your x3 and BH-503 before, you should have your paired devices. So after you connect manually, the headphones should connect to x3 next time automaticly. :)
1helpful
I RECENTLY PURCHASED SAMSUNG WAVE MOBILE S8500 AND ALSO NOKIA BH 505 BLUETOOTH HEAD SET. WHEN I TRIED TO PAID THE BT HEAD SET WITH THE MOBILE. THE MOBILE PHONE IS NOT RECOGNISING THE BLUETOOTH HEAD...
ya i have bought bh 505 yesterday and i am using samsung wave s8500...i have connected my phone with bh 505....its very easy...while turning on your bluetooth headset you have to press and hold for long time till a blu light appears then you turn on bluetooth in your phone and search...it will recognise and pair the device...thats alll ucan use it now...itss awesome....
21helpful
3answers
Nokia BH-213 unable to Pired with Nokia E-63,it stopped suddenly
I also experienced the same problem. After trial and error I realized that the bluetooth device needs to be reset to fix this issue.You may reset the bluetooth device by deleting the pairings from the headset or reseting the headset. Switch off the headset, and press and hold the multifunction key for over 8 seconds. Start pairing the device again. It should work fine now with default passkey 0000
I get a nokia 5800 xpress music mobile before i connect it to nokia bh-604 bluetooth headset and its was fine then i downloaded new software to my mobile i tried to connect it with nokia bh-604 and my...
the problem was the bluetooth headset was already registered with a mobile phone ,first format your bluetooth headset by long pressing + button and power button or long pressing the poer button
6helpful
16helpful
2answers
How to connect LG cookie with Nokia Bluetooth BH 101
Put your Nokia Bluetooth BH 101 into pairing mode - this is normally done by pressing and holding the power key for several seconds. An alternate bleep will sound with a flash light to indicate that you are in pairing mode.
Now using your Cookie, press Menu > Settings > Bluetooth > Search
Your Cookie will find the Nokia BH101 bluetooth headset and then it will ask for a pass code. This is usually four zeros (0000).
You should now be connected!
15helpful
Power it off
Top Nokia Radio Communications Experts
Grand Canyon Tech
Grand Canyon Tech
john h
Are you a Nokia Radio Communication Expert? Answer questions, earn points and help others
