Looking for some facts about what kind of voltage my 24 volt Dewalt batteries and chargers should read between pins..also out put of charger
SOURCE: 18 volt charger (Dewalt)
Where are you getting 130Vac from?
The proper thing to do is get a Variac which is a variable ratio
transformer which can step the 130 down to whatever you want. A
10 amp one will cost about $90 though. They last forever though,
so you might get one much cheaper on EBAY.
Actually, the chargers for stuff like cordless drill batteries are
switcher types that can tolerate quite a wide range of input
voltages. Some can go all the way from 110 to 220. Does
yours have a spec for the input range? Even if it has a tight
range it will probably handle 130V.
SOURCE: Dewalt battery charger
You will need he correct charger, the 24V will destry a very expensive battery.
SOURCE: I HAVE A 36 VOLT DEWALT RECIP SAW, THE BATTERIES
Charger blinks while charging, stops when batteries are fully charged.
New batteries may not be charged from factory. Let them charge overnite and see if it stops blinking.
SOURCE: I HAVE DEWALT CHARGER DE9116.ITS OUT PUT VOLTAGE
check output voltage on charger label most chargers are not regulated so if it says 18 volt output it may put out 24 volts but if its putting out 51 volts it may have a short batteries will get warm but not hot replace charger
SOURCE: My new Blackmax drill battery charger does not put
You can find a repair center on the link below. You just need to put your zip code in to find the nearest one to you.
http://www.blackmaxtools.com/customer_service/service_center_locator
Good Luck
