Our Frigidaire washing machine will not drain. We have changed out the timer switch thinking that electricity wasn't getting electricity to the water pump. We had the water pump checked and it is working. Any other suggestions?
Buba, check the lid switch for proper operation, on a lot of models if the lid switch is bad, no spin, no drain. You said you had the pump checked out. Im assuming that it was removed to check for a sock or other garment lodged in the pump. Other things you can check would be the hose from the pump to the tub, make sure it's clear and the drain hose where it exits the washer. Hope this solves the issue..
