2 pumps which one may have indicator. can fuel sensor be replaced? how does fuel get from one tank to other.
SOURCE: location Fuel Tank Pressure Sensor on a 2005 chevy express van
lOOK UNDER THE REAR OF THE VEHICLE ABOVE THE SPARE TIRE ON A CROSSMEMBER BETWEEN THE FRAME RAILS.
SOURCE: Full tank of gas and getting low fuel indicator on dash
Bad fuel level sensor. Unfortunately it is located inside the gas tank. Fairly common problem on GM's. Due to sulphur in fuel. Corrodes the sensor tabs. Expensive to have repalced and NOT a do-it-yourself project, unless you have dropped a tank before.
SOURCE: my car fuel level gauge sometimes goes to empty
Mine too! I have a 2007 Chevy Malibu also and I knoticed it does that or bounces up and down once my tank gets to half full. Have you found a solution? Sometimes my check engine light comes on and sometimes it doesn't.
SOURCE: Try to fill gas tank, gas pump nozzle clicks off,
There should be an air vent coming from the top of the gas tank back to the top of the fuel tank. Possibly kinked or pinched, try pulling the fuel nozzle about half way out and filling the tank on the lowest setting the fuel pump will let you.
Please take a moment and rate my answer...........Thanks
SOURCE: slow filling gas tank
Sounds like someone put something in the fill tube. It is easy to pull off then run high air pressure through it
