The video showing on channel 2 is showing on channel 9, the video showing on channel 4 is showing on channel 11, the video showing on channel 6 is showing on channel 13 and the video showing on channel 8 is showing on channel 15. Restarting the DVR unit temporarily fixes the issue however it over time it comes back to displaying the incorrect images. Both cards in the DVR unit have been placed. We are using CAT6 cable to connect the cameras to the DVR unit. We are getting good tone from the pairs of wires that we are using to send the video to the DRV unit. We are using a BCI PASSIVE CCTV BALUN to connect the cameras to the CAT6 cable and then the CAT6 cable to the DVR unit. Any suggestions in resolving the issue is GREATLY APPRECIATED!!
First you need to isolate the problem. Step one - make sure the video from the cameras is correct - use a monitor and check each input separate. If the video is correct, use one camera and start from input one on the DVR and check all inputs - in other words plug your camera in input 1, check for video to make sure is correct and shows up in the right place, than go to input 2. This way you check your DVR cards. If the video shows up, but in the wrong place - check the settings on the DVR - you might be able to change the physical input in the viewer.Or you might have a bad DVR.......do a search for DVR Doctors in Google - in case you need repair.
