It drills but it wont hammer it just makes noise..?
SOURCE: Bosch VSR 1199 hammer drill keeps slipping in hammer mode
Inside there is a little plastic shaft, where the selector hooks to. They have had problems over the years stripping. Replacement part is still plastic. Yay! You may need a bearing puller or find some way to get the clutch off the shaft. Lemme know. Please rate me
SOURCE: New bosch psb 550 re with hammer action. Hammer
your pin under the selector switch my have broken off. also the hammer rod could have broken too. if its drilling and not hammering that more likely. you may be under warranty call bosch or log on and go to dealer locator's for the closes dealer to you. hope this helped
SOURCE: Bosch GBH 2-20 SE hammer drill stopped working
hi
check the cord and the switch to have continuity,the wires,the brushes,the rotor and stator.
regards savumihai71
SOURCE: releasing bit from tool bosch gsh11e hammer drill
Grab the black plastic sleeve where the bit goes in and pull it back, and while you are pulling back the sleeve pull the bit out.
SOURCE: The brushes on my Bosch hammer drill have worn
Hi, sorry you have been struggling to find a service centre,this is a link for service centres in the Shropshire area http://www.boschdesign.co.uk/dealer_locator/loc_result.asp?strLocator=&strPostArea=SY&strType=ysn_bsc&intProduct=
Please be aware that if the brushes are badly worn this may indicate a more extensive and more expensive repair
Hope this helps
