I have a Samsung HLR5067WAX/XAA - it has been working great with no problems until just a moment ago. I was watching a show and there was a loud POP and the picture went dark immediately. Right after this happened (or maybe WHEN it happened) there was a strange high pitched sound fading in and out and I was having trouble turning the set off. The sound continued until I finally unplugged it and when I put power back to the set there are 3 lights flashing on the front power button. The lights are "Timer/Lamp/Stand by Temp". Any ideas? Bulb? Is it normal for there to be no warning prior to such an event?
SOURCE: No picture on Samsung HLN5065W
sounds like the color wheel has gone bad..the part is not very expensive but it takes some work to replace it
SOURCE: Burned out lamp?
First. Turn on the set and see if the Lamp Illuminates, If so then you have a bad Color Wheel. If the Lamp does not light up, you have a bad lamp.
Take out the lamp and look to the center of the lamp. If you see broken glass inside you have a bad lamp.
SOURCE: my sasung HLR5067WAX/XAA keeps shutting off,I have
which leds flash? all 3 = lamp error, could be lamp, ballast, or colorwheel or dmd board (rare)
SOURCE: my samsung HLR5067WAX/XAA picture is getting
The 120 Watt lamp is probably losing High pressure Sodium and will need to be replaced. Lamp Code BP96-00826A (P120W)
Would be the first thing to replace.
