Could you specify if noise is coming from : - The freezer - The outside back of the refrigerator - The bottom of the refrigerator
Hi Dov Dror, Do you think my post sounds like a fan motor?http://www.fixya.com/support/t15255490-g... thanks
we tried to work it out but it is really hard to tell. it does not seem to be from the freezer or the bottom of the fridge, and is perhaps coming from the outside.
HI there,
I have just moved into a new place the refrigerator makes a high pitched sound. It is coming from the back. (maybe related tot he ice maker).
It occurs when the door is opened, lasts for about 15 minutes, and then stops.
I have a Kitchen aid side by side. A High pitched noise started after I replaced the water filer and emptyed the ice maker. The noise appears to becoming from the inside-not back or bottom and continues well after the fridge is unplugged.
I have the same problem and we just had the refrigerator delivered today. It is a high pitch, it seems to be when the compressor is running at the bottom. It does stop for a few minutes but then when it turns back on it is very annoying.
I have a Summit. The compressor emits a 3500 hertz frequency noise, which most likely has to do with the rpm of the compressor itself. Not as a mechanical engineer but an audio engineer, I can tell you this frequency lies in the range that is classified as most fatiguing to the human ears. It's super annoying. I have had no success in muting the noise. Anyone?
Loud high pitch clicking or clanking noise on the left side in the back. Looks like the compressor.
It has been making odd noises for a time but then stopping but now noise is continuous. eech!
Its clean underneath and leveled properly
Clean underneath, leveled properly.Noise continues when unplugged.
the pump runs fine but has a high pitched howling noise
