I Have Fisher and Paykel Washing Mashine washing mashine MW511 top loader was running good but this morning tried to start but it is making a beep beep tone and flashing lights. what does that mean ? please help
It is giving out a fault code,
Of the 8 wash progress lights, tell me witch are on,
I will tell you the fault code and info on how to fix.
i have the problem with the two outer lights flashing
My MW511 lights are 3,4,5 flashing. I see that it's error 56- which is a bowl check. I reconditioned the RPS connected to the Stator. I also brought a secondhand motor controller but it was faulty. I put my original thr
My MW511 lights are 3,4,5 flashing. I see that it's error 56- which is a bowl check. I reconditioned the RPS connected to the Stator. I also brought a secondhand motor controller but it was faulty. I put my original motor control back in. The problem is that it won't agitate or spin with every wash. Sometimes it works. I read a comment by a technician who said to replace the 3x 332k resistors with a 1 meg Ohm resistor. WILL DOING THAT FIX THE PROBLEM? And does anyone have any other suggestions?
This repair should fix the problem. Also check for corroded tracks on the bottom edge of the board and fix them..
Thank you so much! You advise worked! Our washer is working perfectly now. It only cost us 50 cents for a 2 pack of 1 meg Ohm resisters, so you saved us $800! We were about to go out & buy a new washer but now we don't have too. Thank you so much. You are a genius! We can't thank you enough.
SOURCE: Problem with Fisher & Paykel MW511 toploader washing machine
Sounds like a possible main control card issue. If this machine is under warranty please call your dealer as these boards can be expensive.
SOURCE: fisher & paykel (mw511)
check out the DRAIN MOTOR PUMP , its a small motor with 2 hoses connected to it , it could be clogged , need to remove it , inspect inside the impellers for any debri , clean it , re install and try again , hope this helpful AJ
SOURCE: FIsher and Paykel washing machine won't stop beeping.
if you remove the back panel you can look under there, there should be atrouble shooter/techsheet that will let you know what the flashinglights mean. if not theres a tech support number to aid you as well
Having the same problem. Any ideas at all? It's really frustrating.
nwesthamz
Rank: Apprentice
Rating: 75%, 1 votes
mw511 fills with water but cylinder isnt spinnig and when it stops
filling nothing happens. However sometimes it will go complete cycle
ans a noise can be heard on spin cycle even though it is not spinning.
As thoiugh the motor is not engaging with the cylinder
Was this helpful?
Yes
No
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
