Question about Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
How to fix out of range problem on sony bravia with pc
When i connect hdmi cable from pc to sony bravia it appear black screen on tv and in left top angle stay out of range
    New Friend:
Well I just changed the resolution settings in my android box to 720 from 1080p > plugged it in and my box now works...simples.
Posted on Jun 12, 2017
6ya staff
SOURCE:
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: Sony Bravia 40inch how do I remove input icon
Press " i " (info) button on TV remote and on-screen display will disappear.
Posted on Jan 26, 2009
Anonymous
  • 98 Answers
SOURCE: sony bravia klv-32t400a hdmi input through x-box
The problem is that, according to the specs for that TV, it doesn't support 1080p.
That's a 720p television you've got. (Specs here)
While the specs say that it supports 1080p, the resolution says it supports 1366 x 768, which is only 720p, not 1080p or even 1080i.
You may want to contact Sony for clarification, because their specs for that tv are contradicting each other.
Posted on Mar 19, 2009
Anonymous
SOURCE: Sony Bravia television hdmi stopped working
Installing a new software update will this issue. All you need is a compatible USB flash drive. Go to support on Sony.com. Look up your tv model and if there is an update, just follow the instructions to install it yourself. I have a KDL-46S5100 and this worked great. The download and instructions page I used was : http://esupport.sony.com/US/perl/swu-download.pl?upd_id=4769#install
Posted on Oct 10, 2009
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: How do I remove the input banner at the top of the
Press Info/ Display button on TV remote, on-screen display will disappear.
Thanks.
Posted on Dec 06, 2009
Anonymous
SOURCE: hdmi port stopped working on sony bravia
I have a Sony Bravia model KDL-46s5100 that had the same problem. All HDMI ports stopped working. I don't know why this works but unplug the TV for about 30 sec, then plug it back in and hold down the power button on the tv for 10 seconds. Like I said I don't know why this works but it worked for me. Good luck.
Posted on Mar 21, 2010
We have sound but no picture
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 467,264 views. 2:30. LCD & LED TV Repair - No Image ...
How to fix sony bravia has black screen - Digital TV - Streaming ...
www.tomsguide.com/forum/56867-4-sony-bravia-black-screen
Aug 19, 2014 - 12 posts - ‎11 authors
Hello, My Sony Bravia TV screen has gone all black. The green on/off light comes on,but no picture appears. The model ... Your solution solved the non picture for live tvbut still no picture (just sound) fir OnDemand. Score. 0. No picture on LCD TV with HDMI cable plugged into ...
Aug 4, 2014
Tv problems picture ok but no sound - HDTV
Sep 8, 2011
More results from www.tomsguide.com
Dec 14, 2015 | Sony BRAVIA KDL-55XBR8 55 in. HDTV LCD TV
DVD hooked up to sony bravia tv: have dvd power on, but can not get any set up menus (or anything) from dvd to show on tv screen.Unable to set up remote as menu does not appear on tv screen.
Hook up the player with RGB (Red-Green-Blue or component) cables and try the picture. If everything works OK, then go to the menu and turn on the HDMI output and set the resolution (if needed).
Not every HDMI unit works with every HDMI TV. You may also have a bad HDMI cable. On a DVD recorder, you may have your HDMI cable connected to HDMI IN. You must use HDMI out.
Mar 28, 2010 | Sony RDR-GX7 DVD Recorder
I have an LCD Sony Bravia KLV-46V400A, and a Dell Laptop both TV and PC have HMDI connection, i pluged them both using HDMI cable, however i am unable to view anything on my TV screen and nothing on my pc.
make sure that your pc is shutdown(off) when you plug the hdmi cable in your tv. First, plug hdmi cable into tv and turn on tv. Next, power up pc and it should see your tv. There should be an option on the pc to set the output a projector.
Mar 26, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
I have a Sony DCD Recorder (RDR-HX780) and Sony 40" 1080P LCD TV (KDL40S510) "tripple checked lines and HD cable connection." Problem (which occurs randomly and is anoying): When switching to DVR or...
Try this: got to www.sony.com mouse over "support" then click on "drivers/software" enter your model #(s) and then you can check for firmware updates, the symptoms that you list, unfortunently are somewhat common when connected via HDMI cables.
Check for updates on both product that you list.
Good luck !
Jan 31, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Screen goes blank / black, sound still works
It sounds like your LCD Screen is no longer working. I would try contacting Sony and ask for a refund. I had the same T.V and the LCD Screen had gone out. A techniction came out and Condemned the screen and i had to pay $500 for a new T.V.
Apr 13, 2009 | Sony BRAVIA KDL-40V3000 Television
Sony bravia kdl40l4000 hdmi issue
i have sony bravia. i couldn't connect to my ps3 with hdmi cable. but i get only audio. i think it is with the tv settings. can you help
Dec 08, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV Logo
1,645 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
