I would like my picture to have the date and time when it was shot. How can i set this option in Olympus Stylus 820 Digital Camera.
SOURCE: Problem transferring photos from my digital camera to my PC
iF THE CAMERA SHOWS THE SCREEN and THE COMPUTER DOESN'T GO 'BONGBING' when the menu option is selected, try a different usb cable, or usb port.
SOURCE: Instructions for replacing Olympus Stylus 820 battery door
Give a call to 305-653-7355 they can help
Ask for Zack
SOURCE: picture error message on olympus 1200
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the Picture error message and the card can be used again. The picture error message indicates that this image is now corrupted and unable to be viewed through the camera.
SOURCE: Olympus Stylus 300 need date/time stamp to print
On Page 113 of the user manual (see the link below) shows you how to set the menu up to print the date onto the print when printed
Top Menu >Play >Print <up down arrows>Then select No, Date or Time
the user manual is available from here
http://www.olympusamerica.com/cpg_section/cpg_download_manuals.asp
choose your camera from the dropdowns
Direct link to the user manual
http://www.olympusamerica.com/files/oima_cckb/Stylus_300_400_Digital_Mju_300_400_Digital_Reference_Manual_EN.pdf
SOURCE: I just purchased an Olympus
Olympus Stylus Tough 3000 prints date on image if you connect it directly with printer to get print out of pictures. Printer must have PictBridge mark to receive picture data directly from camera. Usually this type of printer calls photo printer.
Olympus Stylus Tough 3000 does not show time/ date stamp in picture files either in camera playback or transferred in computer. It only prints date info while printing photos through photo printer.
Connect camera with printer and select Custom Print in setup/ print mode, you will see Date option (with/without) to get photo printout with desired info.
Above info also available in user manual, check page-54 fro more details. Click HERE to download related user manual free copy.
Hope these info will help you.
Thanks.
