Question about PANDIGITAL Digital Book 843967071153 Tablet PC
Trying to download new firmware but i get error assembly binding logging is turned off
S/n 70200010123378
    Champion:
  • 274 Answers
You'd better to contact the supplier for tech help.or search this error on Google if there is an answer to solve .
Android 4.0 Tablet PC
Posted on Feb 08, 2012
6ya staff
SOURCE:
Why cant i downdload apps free
Mate same with me, I tried to uninstall some of my google factory settings but my phone wouldn't let me so I stopped them from updating and after a while I started getting an error code 491 when I tried downloading apps from google play store. I googled 491 and found this link that showed me how to fix it, If it starts happening again then just repeat this link....CHEERS..
http://android.stackexchange.com/questions/83432/downloading-from-play-store-gives-error-491
Mar 16, 2016 | Tablets & eReaders
Tip
How to fix a hanged/frozen/non responsive Pan Digital Novel E-Reader
If your Pan Digital Novel Reader... does not respond or hangs, it means the unit/device has frozen. This is a software/OS (operating system) problem.
Usually, resetting should do the fix. To reset, push the hole at the back of the unit with paperclip and the unit will reset. But if you have reset the unit by pushing the small hole at the back with paperclip (which means reset) and that seems not to solve the problem, then it means the operating system of the unit is corrupt. This is a software problem and to fix this problem, you need to install the firmware for your unit.
Firmware helps to remove the corrupt software and re-install a new one. Your unit will be as new once this is done.
Upgrade via PC
This option is for Windows PC only at this time.
With this method, you must connect your pandigital novel to a PC and then run a downloader program which automatically downloads the firmware to your device.
1. On your computer, go to www.pandigital.net/downloads.
2. Choose the "Upgrade with Your PC" option.
3. When asked to Save or Run, select Run.
4. Follow the prompts in the Upgrader window to download the firmware into your device.
5. After the download is complete, turn your device off.
6. Press the Volume + key plus slide the power key on simultaneously for 5 seconds, and then release both.
7. Your device is upgraded and restarts automatically.
8. In the Language setup screen, tap Save with English selected (other languages will be available in future firmware upgrades).
9. In the Date/Time screen, if necessary, tap in the Time Zone, Date, and Time fields to set the correct time for your location. IMPORTANT: In order to connect with your Barnes & Noble online account, the Date and Time must be set correctly according to your location.
10. Tap Save.
11. The HOME screen is displayed.
Re-Upgrade
If you have previously performed a firmware upgrade to your device using one of the above methods, we recommend that you move the existing upgrade file into a different folder before performing another upgrade, which allows you to revert back to the existing version if desired.
1. Connect the device to your computer.
2. In a Windows Explorer or Finder window, create a new folder titled Firmware, and then copy the existing upgrade file into the Firmware folder. (The upgrade file is named similar to SYY_MM_DDK_PD_INX7E_ENG_6410POP.)
3. Perform the new upgrade using one of the methods above.
Revert back to Previous Version
2. In a Windows Explorer or Finder window, delete the upgrade file from the root, and then copy the upgrade file from the Firmware folder back into the root of the device.
3. Turn your device off.
4. Press the Volume + key plus slide the power key on simultaneously for 5 seconds, and then release both.
5. Your device is upgraded again and restarts automatically.
6. Follow the prompts to re-set your language and date and time.
I hope you found the above helpful.
Regards.
on Sep 27, 2011 | Tablets & eReaders
When trying to log in to Facebook I get error code 1200
Try to delete the app and redownload it. It will not delete any of your personal information.
Make sure you can skill log into Facebook on a computer and that you are not getting an error there. If you are getting it on another device after re-downloading the app, get in touch with Facebook.
Mar 27, 2015 | Apple iPad 32 GB WiFi Tablet PC
I am trying to fix a friend's digital2 tablet the s/n is m961gpl1312 and every time it starts up it goes to the Android recovery page and I've tried to factory reset it and then restart it but it still...
you probably will need to update the firmware
D2_961 Firmware Update Instruction:
1. Download the D2_Firmware in the link below
2. Use an archiving software (Winzip, WinRar, 7 zip etc.) to extract the Firmware Update package and export it to your computer's local disk (ex. C:\)
3. Open up the zip file and there will be 3 folders as shown in image
4. Open "Pad Product Tool 1.05_02" folder and click on "setup.exe" to install update tool.3-284x233.png4-284x233.png5-284x177.png
Click "Next" all the way until the program starts installing. Click "Close" when the software has done installing.
6. Click the 7.png icon and choose the firmware file "jellybean_atm7029_m2909_131216.fw" from the "FW_m2909_961_1115_1216" folder.
7. When the firmware file loads, it will show up on the PAD Product tool.
8. Now, click and hold down the "Volume - "key on the tablet.
9. While holding down "Volume - " key, connect the tablet to a PC using the USB cable.
10. Still holding down "Volume - "key, use a paper clip (or a small pin) and press the "Reset" button on the back of the tablet ONCE (and let go)
11. The 9.png icon will turn into 10.png . Click it to start the firmware update.
12. After the update is complete, remove the USB cable first, then turn on the tablet.11.png
13. The initial start up time may take up to 50+ seconds.
14. After initial start up, tablet will require a reset. Please press and hold the reset button for 10-15 seconds to reset the unit.
http://cloud.d3reaction.com/public.php?service=files&t=2ff2083703cca9cfa4050bd47a793864&download
Jan 19, 2015 | Digital2 Tablets & eReaders
Where can i download the firmware for my tablet irulu 10.1 "
Only when a brand like irulu offers an update of the firmware, you can download firmware. But I think now you ask for firmware you even can't use new firmware. I think you have bricked your tablet. But to load firmware, your tablet needs to work correct. If during an update (or while rooting) something goes wrong, you can't put in new firmware, because the tablet does not know what to do with the USB connection or with the memory card holder. Only a workshop with the correct tools can put in some firmware.
As soon as irulu has an update of the firmware they will notify registered users they can download the firmware and they also provide a manual, how to do the update. There are always warnings, if something goes wrong during an update, you can end with a bricked tablet. But if it is a regular update, they also tell you who to contact if something goes wrong.
Try to fine a certified irulu repair centre and ask them for help. (and what it will cost)
Aug 25, 2014 | Tablets & eReaders
How do I get past the ice cream screen to my log on screen?
Have you downloaded the firmware upgrade? You'll have to download it to a micro SD chip via computer. Insert the chip into your tablet and do a hard start by holding the down volume and power buttons simultaneously.
May 06, 2014 | Polaroid 7-in. Internet Tablet - Other
Kocaso M1070 turns on goes to bold android screen and hangs please can anyone help my 6year old is heartbroken I bought the tablet from mighty deals in June when I had the money and gave it to my son...
Anyone from Kocaso, or anyone who owns one of these please jump in and correct me, please!
I suggest first trying the toll-free help for Kocaso: 1-866-777-0079. They are open M-F, 9:30am-6pm EST. Follow exactly the help instructions from that person first! Ignore the rest of this!
Do you know what your son did to induce the error--if anything? Do you still have the manual? Have you tried soft and then hard reset?
Use your PC/Laptop/Mac--not a tablet--to navigate to these links and downloads.
I've done some searching: Manual--Download from this link and open the PDF file with Adobe Reader on Windows. (If you don't have Reader installed, the most current version is a free download at Adobe.com.)
http://www.kocaso.com/manuals/?model=M1070
Firmware Upgrade: Their manual doesn't appear directly to indicate how to perform a hard reset without upgrading firmware. Telephone support should instruct well about that, though. See the manual on page 13--that's likely your tablet's problem! That refers the reader back to "Should I perform a firmware update?" on page 12.
I hope that firmware update isn't required: It may prove very risky--perhaps making your tablet useless.
Note the screen picture on page 9 of the manual: "Backup and reset"--if you can navigate to that, click navigate further in the menu to "Factory Data reset" (that's what my Android 4.0 tablet indicates, anyway--it's likely the same wording). Execute, (and, click "Yes, etc.") if possible: It likely isn't possible, is it?
Here's the firmware update site for the 1070 models: The procedure is somewhat involved, yet not impossible. Actually, two versions of the 1070 tablet exist--1070A and 1070B. You need to determine which one is your's. Definitely click and read "Serial Number Checklist.txt to help determine which firmware update to use. It appears somewhat ambiguous with one model. Again, telephone support ultimately should prove correct here, in your case.
http://www.kocaso.com/firmware/?model=M1070
Yet again, talk to a person at Kocaso first, always ignoring all of this, if possible!
I'm making a guess here: Note step 2 of the "Firmware Update Instructions.
"Turn off the tablet."
Then "Press the Volume + button of the tablet and keep it pressed. "
That point in the process likely should offer an option for factory reset, given that you can't navigate your tablet's "Settings" menus. Navigate on that screen and execute--clicking "Yes," or otherwise affirm.
Try to get in touch with the company! Online, they provide a form in 'Contact Us"--use that in place of calling, if necessary.
Dec 16, 2013 | Tablets & eReaders
Can't find temporary recovery log
the only solution i can find to your problem is to delete the firmware update you've put on your table,you need to wipe the data,just reset it to factory settings,,just hold the back and power key then if you see it light ang the logo just release the power key the back remain,then your on the system mode just select wipe data fastory reset or what ever you want just press up and down volume to select..then press back button to start.....hope it help....
May 28, 2013 | Tablets & eReaders
I downloaded a new version of facebook application, after that i cannot log in to facebook, error code 1 (FBPAPIError) appear.
Are you absolutely sure you're using the correct email address and password? Similar things have happened to me, only to find out it was a wrong or outdated password. If you're positive it's correct, try deleting and reinstalling the Facebook app by going to the home screen and pressing and holding the Facebook icon until the icons start wiggling and an X appears on it, then tapping the X. Next, simply go to the App Store and download Facebook again.
If you have the same problem after trying this, maybe try logging into Facebook from somewhere else. If you can log in from other places but not on the iPad, make sure you can get on other websites such as Google on it, just in case it's a connection issue. I hope this helps :)
Oct 14, 2012 | Apple iPad (16 GB) WiFi Tablet PC
PANDIGITAL Digital Book 843967071153 Tablet PC Logo
231 people viewed this question
Top PANDIGITAL Tablets & eReaders Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Vincent G
Vincent G
Are you a PANDIGITAL Tablet and eReader Expert? Answer questions, earn points and help others
