QuickBooks is an extremely efficient accounting instrument for tracking company operations. Although it is helpful, it tends to show minor mistakes that influence the workflow of an individual. QuickBooks error code 6210 is one of the most common problems requiring instant resolution. If the above solutions don't work and the mistake persists, it implies the QuickBooks file gets infected and gets damaged. To solve this user, the QuickBooks software requires to be reinstalled.The customer care of QuickBooks can be contacted round the clock as a representative can approach the QuickBooks Tech Support number 24/7.
How to fix it
Your solution depends on what action you were taking when the error occurred. Please choose the appropriate selection.
You are opening your company file
You are restoring your company file
You are creating a back up
http://support.quickbooks.intuit.com/support/articles/SLN40226
for more help visit
QuickBooks Technical Support
SOURCE: Cannot install quickbooks pro 2005
Download the latest flash player from www.adobe.com
Thank you for using FixYa!
Az.
SOURCE: I am installing Quickbooks Pro
Try this:
Open the Program Compatibility troubleshooter by clicking the Start button , and then clicking Control Panel. In the search box, type troubleshooter, and then clickTroubleshooting. Under Programs, click Run programs made for previous versions of Windows. Follow the instructions in the troubleshooter. If you cannot install a program, insert the installation disc for the program and, using the troubleshooter, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The troubleshooter is not designed to work on programs that have an .msi file name extension.
