SOURCE: can't progam my direct tv remote to operate my westinghouse 32''tv
I don't have DTV anymore, so I don't remember the exact code I used for my SK-32H240S, However, I do remember that I found one that worked at this site. Scroll down to locate your remote series # - it most likely will be printed on the upper left corner of the front of the remote - as an example, mine says RC64. Click on the corresponding listing, then follow the directions on the site. I tried only a few codes before finding one that worked correctly. Good luck.
SOURCE: Westinghouse tv Mod.SK-32H240S COMES ON SHOWS THE
Having the same problem and wondering if this solution worked :D
SOURCE: Westinghouse SK 32H540S when i Turn on TV, get
The problem is cause by the transformer on LIPS inverter (Power supply + Inverter board). You could see an obvious burn on the 1 of these transformers ( There are total 3 black transformer on this board). The part number is 4302H. It is available online at http://www.lcdparts.net/TransformerDetail3D.aspx?ProductID=2775
