I want to control my cable box with the tv remote
Hello!
refer to your TVs owners manual. You will find codes for common set top boxes there. all the new TV remotes are universal. If you see "cable" or "cbl" button on remote, you will be able to do so. Worst case scenario: you need to buy universal remote or use your cable box's remote to control basic functions on TV. Codes for TVs are included with cable box's remote control. Or, you can call your provider and ask for "Sony Bravia"codes. If you have a satellite box, codes are supplied right inside "setup" menu of the box.
Good luck,
Alex.
SOURCE: KDL-32XBR6
Try resetting the TV by holding down the "up" button on the remote (with the TV powered on) and then, while you hold down the up button on the remote, hit the power button on the TV. This should do a "factory reset" which will wipe all settings in the TV. There is no reason why the TV should not "remember the last input it was on when it was ;last turned off. Also be sure that the TV is not plugged into a switched AC outlet, like the outlet on the back of the cable bix. The TV should be plugged into an output that receives power at all times.
SOURCE: connecting a standard cable box to an HDTV and
are you connecting by scart ? if so some hdtvs send signal backfeed/try aerial tv out to tv/also try basic scart lead as scarts can be faulty dont fit a pound shop one get a top one from maplins etc
