How tough is it? Do you have to remove all the tub etc. to do this? Can you get to it through the front or how do you get the clamps off?
Thank you!
Remove the top and loosen the clamp around the spin tub. Remove the two screws on the hinge on the door to get it out of the way. remove the clamp around the diaphram in the door. This will require 3 arms and a trained monkey! Seriously, get 2 screwdrivers andat least one pair of pliers as this is hard! Slip a screwwdriver under the ring between the rubber folds. Slip another one opposite from this one and use a pliers to pull the ring free. Its hard but you can do it. Reverse the process when installing the new one. Make sure you have already aligned the inside up top for the air vent for the dry tube. Use a zip tie to seal that part around the dryer vent tube. Tighten the inside clamp before putting the ring back on the front! Have fun!
