For 1209 there is no format code the only thing is to delete all the data like contacts, messages etc.And restore it by selecting "Restore factory setting".Good luck
What code are you asking for? If it is a network unlock code, You can get it from www.wickedunlock.com/nokia-1209/rs11wp9/ at affordable cost with easy unlocking instructions.
Hello, Your default code is 12345 or 00000 Or you can restore factorry setting. for soft format dial *#7780# or *#7370# which restores the factory settinngs but
if you format the whole phone memory then follow the procedure below (
remember one things this will deletes all your mesages, all contacts,
photos, notes etc in the phone memory.. your phone is like a new phone Switch-off
your phone. 1. Press and hold 3 keys; Green dial key, * Star key, no. 3
key on keypad and then press the power on/off to swtich on the phone.
Remember, do not let go the 3 press and hold keys until you see a
formatting word screen show! 2. After a few minutes when the Full phone
formatting completed, your phone will back to original system and
factory settting.
To format your nokia 1209, all you have to do is to go to the menu of your phone, select the settings, then select the restore factory settings, it would request for a code, so enter the security code for your phone and it will restore the phone back to the settings it had when you first bought it.
If you do not have the security code for your phone, then i will strongly advice that you flash the phone with the appropriate software.
Ensure, you save all your phone contacts to the sim and messages, because after flashing or restoring factory settings, all your information will be wiped off the phone.
You may try default phone and security code to remove restrictions. ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
if not solved tell me your IMIE number
type *#06# on your phone to get IMIE number
if not solve
you may need to format your cell phone
you can format your mobile by following steps:
1. Switch off your Nokia phone 2. Now Press following key sequence *#7370# or *#7780# 3. Enter Default lock code is 12345. 4. While holding these buttons, press the power button and switch on the phone. 5. Wait for message ‘Format
