Dynex DX-LCD19-09 19 in. LCD TV Logo
Susan Malia Posted on Feb 01, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Dynex 1909 has no sound other than a white noise type otherwise all is fine
Level 3:
Top Expert:
  • Dynex Master 76,851 Answers
  • Posted on Feb 01, 2012
Dynex Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14986825
Points
237762
Hello
Your Dynex TVs electronic tuner has the fault. Replace it. It will look like a small steel box, to ehich antenna cable gets connected.
Denon avr-1909 has sound but no video, tried everything!!
Denon requires that you assign video to specific ports. HDMI, RCA or any other- you have to select which type and which port and you will get video.
2answers
Dynex blu ray sound and no picture
try a new HDMI or try compusite cables they are five cables green blue red white and black or you could try just rca jacks yellow white and black the only problem with rca jacks is it wont be HD but you will have sound and picture
Dynex headset does not shut off sound from desktop when plugged in usb port
Plug the USB connector into an available USB port.
• Check your computer's volume level.
• Check if your computer's volume is muted.
• Check your operating system's audio input and output settings.
• Check the headset's volume and mute settings.
• Restart computer.
Otherwise, I would recommend pursuing replacement options
I just bought a new dynex 32 inch DX-32L152A11 tv. I tired to hook it up to my dish system and the picture is black and white and no sound.
Hello Debbie,
This is due to incorrect connections between the dish box and the TV. You may find that if you select another input (AV1) on the TV, you will have sound from the dish system, but no picture.
I suspect you are using an RCA type AV cable with red, white and yellow jacks on both ends. You've most likely connected the yellow jack to a socket labelled Y, Pb or Pr on the back of the TV and then selected the COMPONENT input on the TV.
If you are using a cable with red, white and yellow jacks, please make sure they are connected to the sockets on the back of the TV shown below. I've ringed the socket for the white jack in green for better visibility.
Once you've done this, select the AV1 input on the TV by pressing the INPUT button on the dynex remote, then use the arrow keys to highlight AV1 and press ENTER to select.
If this does not solve your problem, please let me know which type of cable you are using and the model number of your dish box. If you don't know the technical term for the type of cable you are using, please describe it as best you can, i.e. how many plugs/jacks are on each end of the cable and whether they are color-coded.
Hope this helps. If you need further assistance, please reply to me by clicking on "Add a Comment" below your question.
Regards,
BElectric
3helpful
Dynex dx-32l151a11 the picture is black and white with the dvd player
With a Black and White picture it sounds like you're trying to connect the DVD Player's "Composite" connection to the TV's Component Connection.
Composite is a 3 wire system with Yellow for the video, and red and white for the audio. On your TV this connection is located on the side.
Component is a 5 wire system, with Blue, Green & Red for Video, and Red and White for audio. On your TV this connection type is located on the rear panel.
Check to make sure you are hooking the DVD player & the TV to the same input types.
2helpful
MY TV PICTURE IS WORKING FINE, BUT THE SOUND IS MAKING A CRACKLING NOISE. I'VE CHECKED ALL CONNECTIONS AND THEY SEEM TO BE FINE. ANY SUGGESTIONS OF WHAT I SHOULD DO OR LOOK FOR? THANK YOU CORKY
The speakers could be going bad or this could be a sound adjustment issue. Check the Bass and Treble sound settings. It could also be associated to bad connections, but if they seem fine it could also be attributed to cables/wiring.
1helpful
Loud buzzing sound on Sanyo AVM 1909
I had a problem like that so I disabled the tv's onboard tuner (input source)and now we use the cablebox's video and audio out to the video and video in jacks on the TV this will work as long as you have a cable box or sat reciever for your video and audio source and of course your TV must have video and audio inputs so it will work.
Good luck Rich
2answers
1helpful
Dynex DX-LCD32-09. tv was working fine, then out
This type of failure could be in the LCD controller board or the power supply might not be providing enough voltage to the main board and LCD controller.
Let me know if you require further assistance locating the boards or part numbers.
White Screen on Dynex LCD
Please stop buying these cheap things.....your out of luck. Parts are not available for these cheap chinnese sets....Thank Bill Clinton. Anyway, sound like the tuner going out. But....you can't get a tuner...Sorry. Just try using a vcr or cable box on video input and change channels that way.
Top Dynex Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Jesse Walters
Jesse Walters
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
