Ive had the freezer for a month now. at first it was fine at 6 and then suddenly things I put in werent freezing, for instance a loaf of bread was only cold after being in there overnight. so I changed it to 2, then things , like bread, were freezin. I filled the freezer up 3 days ago. went to take something out of the freezer for dinner and things, like the turkey, were thawing. took everything out and put some in small freezer in fridge. they are frozen now
SOURCE: Freezer not freezing food even at highest setting
If the unit is running continuously and not maintaining the temperature cold enough the system may have a leak. If it is NOT running continuously the problem could be in the temperature control.
SOURCE: Quit working -Haier Freezer
Our freezer has done the same as Brenda's no noise no warning at all. What is wrong
SOURCE: Any possibility you can help troubleshoot a larger
Assuming the thermostat is set to call for cooling (sometimes they get bumped), check the condenser coils, fan, etc for debris build up and clean as needed.
Is the freezer frost free? If so, it's possible the defrost timer is stuck in defrost. There should either be a mechanical timer or it could be electronic these days. Check for bad connections or any obvious signs of damage (burn marks)
Make sure the freezer door closes tightly
