The clip lock on the chassis/ frame of our Quinny Buzz 4 broke off and now the chassis does not stay folded. Any idea of whether it can be repaired / how much it costs, or whether the unfolding can be stoped with an other DIY solution?
Hi
If you're in the UK a replacement transport clip for your Quinny Buzz can be ordered from your local Quinny retailer or direct from the customer care team on 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays) RRP is 7.50GBP and if ordered direct there is 3.99GBP additional p+p.
If you're not in the UK please visit www.quinny.com and select the country you're in, then choose the "Contact Us" tab on the right side of the screen for your enquiry to go through to the customer care team for your country who can help you source a transport lock.
SOURCE: Quinny Buzz Frame Problem
Try contacting them directly!
This may be a manufacturing problem that they are not aware of !
Click on the link below.Copy and Paste your problem into the email if you like.
http://www.quinny.com/quinny/forms/contact.aspx?mode=contact&language=nl-nl
Hope this is helpful.
Good Luck!
SOURCE: Removing a maxi cosi car seat from a buzz 3 chassi
On the Cabrio Carseat, at the bottom of the handle (when in the upright position) there is a silver button (either side) this would be roughly where the babies hands would be if out-stretched), depress these buttons and the Cabrio should release fine. DONT do this when baby is in the Cabrio whilst you are practicing. If this is a little stiff, when you have released the Cabrio, WIPE a little WD40 (sprayed onto a cloth) onto the adapters, DONT spray it on. This should make the release a lot easier in the future.
I hope this helps.
