Master
- Posted on Feb 02, 2012
Re: Frigidare dishwasher did not spin
Waste Disposal/Sink trap
Empty your food waste disposal
unit if your dishwasher's hooked up to one. If it's not empty, the old
food inside it will back water up into your machine. Check that your
sink trap isn't blocked by unscrewing it from the base of your sink if
you don't have a food waste disposal unit. Make sure your dishwasher or
any other appliances connected to it are not running when you do so.
Incomplete Cycle
You may have opened your
dishwasher's door mid-cycle before it's had a chance to drain. Check the
progress indicator on your machine's control panel. The structure of
this will differ depending on which Frigidaire model you're using, but
it should show the point your machine has reached in its cycle. If this
is the cause of the problem, close your dishwasher's door and let it
finish.
Drainage Pipe
Inspect the drain pipe that runs
from your machine to your waste disposal unit or sink. If this is
kinked or has been squashed under another appliance or a base unit, the
waste water inside your dishwasher will be unable to escape. Check that
water can flow through your waste pipe freely.
Filter
Remove the bottom shelf from
inside your machine and take out the plate covering the filter area. If
you don't rinse your plates before you put them into your washer, food
debris could block your filter and stop water from reaching your
drainage pipe. You can unblock your filter with your fingers. Turn off
your machine's power before you attempt to do so.
