Fisher and Paykel GWL11 Top Load Washer Logo
GEORGE GARFUNKLE Posted on Feb 02, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WAS THERE A RECALL ON FISHER & PAYKEL GWL 11
WAS THERE A RECALL ON THE FISHER & PAYKEL GWL 11 WASHER ,, DUE TO PUMP CAUSING SHORTAGE AND DAMAGE TO CONTROL MODULAR
keith jones
Level 3:
Master:
  • Fisher and P... Master 747 Answers
  • Posted on Apr 21, 2018
keith jones
Level 3:
Master:
Answers
747
Questions
Helped
314327
Points
1478
No not thst i know of but its always been a problem with them over tha last 20 years
5 Related Answers
Anonymous
  • 22 Answers
  • Posted on Oct 20, 2008
SOURCE: GWL-11 Fisher Paykel wont turn on and water on the floor
Look at my issue "eco smart won't drain, smells hot". Mine is top load.
If you see puddle on floor and eventually won't run at all and smell electric burn motor, it could be same issue I had.
Unplug washer. Tip washer back. If you see water dripping through the black motor area, you need to remove the black motor and the white plastic unit above it. Look for a white plastic clip that is attached to bottom of washing machine. Push that clip with your finger and twist the whole plastic unit/black motor. It all comes off in one piece.
Look on side of this unit and you will see 120V or 240V. Mine is GWL10US and is older model. Was told by repairman that new units use 120V. That is what you need to order. It comes as one piece and you just twist it back on. I had done most of this. Repairman came and 5 seconds cost me $65.
Anonymous
  • 144 Answers
  • Posted on Mar 24, 2009
SOURCE: fisher and paykel washer gwl 11 us
ok You have a blown Motor controller module. There could also be another fault that caused this to blow up. eg a faulty drain pump, lid lock or Diverter valve, inlet valve. you'd need to use a ohm meter to test all these. cheers
Anonymous
  • Posted on Apr 06, 2009
SOURCE: fisher paykel codes
There is a code book inside the top of the washer where the electronics are.
seakish
  • 492 Answers
  • Posted on Apr 30, 2009
SOURCE: when the washer (fisher & paykel gwl 11) goes into
Try unplugging the washer to reboot the curciut board. Leave unplugged for 5 min. Then replug and select only one setting. Multiple setting selected in a short period on time will confuse the little brain in the board. Reboot to fix. Be patient!
Lollo Pop
  • 134 Answers
  • Posted on Jul 10, 2009
SOURCE: no power to fisher paykel washer. Replaced pump
PUMP IS ALSO A HEAT SINK FOR THE MOTOR CONTOLLER.
YOU MAY NEED A NEW BOARD
Where is the pump on my Fisher&Pakel GWL 11 AND HOW CAN I GET IT OFF TO CLEAN IT
Tilt your machine back on a 45deg, look up under machine to find pump
pull back on the white lever & turn anti clockwise to remove.
Replace fisher paykel iwl 16 mother board with gwl 11 motherboard
I cannot find your mothers IWL16 model, but I have found various similar machines that are the same phase as your GWL11 machine, the electronics in there although different are compatible, you can swap the drain pumps, there almost universal, avoid the drive shaft machine, fix the other one If you want further help, post a photo of both pcb's (the electronics) After swapping your machine will stil require programming which is simple enough
2helpful
Fisher and Paykel GWL11 Top Load Washer won't drain
Could be something in the pump. The pump is on the bottom of the tub.
It has a locking tab which you release and then twist the pump a hair and it will fall out. Warning: Have rags ready! I have the original GWL service manual and the GWL 11 supplimental manual. Let me know if you want them.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
2helpful
During the rinse cycle, our GWL 11 Fisher & Paykel
The problem is in the pump, so it will not pump out, you will need to find another way to empty it, removing the agitator will make the job easier.
When you get the water out the pump can be accessed from underneath, it turns anticlockwise to remove it,.
I would buy a new pump as it is most likely that is all that is wrong with it.
3helpful
2answers
Fisher Paykal GWL-11 won't advance through cycles. Could this be
maybe blocked drain pump can u hear a buzzing when it tries to drain water
Fisher paykel codes
Fisher and paykel washer gwl 11 us
1helpful
Balance Issues
Depending on the model you have the gwl 10 and 11 have a bal sw located under the console the sw may be engaging causing your problem. ( maybe corroded or shorted ) Or in later and current models they also have bal/shock struts on each side, one of the four maybe worn causing your unit to go out of bal.
Top Fisher and Paykel Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
