When i press throttle the bike cuts out !! starts fine on pull start but wont hold cuts out as soon as you press the throttle any ideas ?? its a mini pocket rocket quad bike petrol 25;1 thanks
SOURCE: problem with the carb on 49cc mini bike
yes clean it with carb cleaner, take it off and take it all apart, every last piece and put it back together, it'll have trouble starting the first few pull but itll go
SOURCE: gio mini quad 49cc no governer won't idle up
change the CDI unite it in the battery case.( price around 35 to 80 bucks )
Testimonial: "Thanks alot!"
SOURCE: pocket bike prblems
Get some engine starting fluid and spray a small amount in the air intake. If that doesn't work take out the spark plug and see if it sparks when you pull the cord and make sure it is not fouled. If it is wet with fuel dry out the plug and pull the cord a few times to clear the cylinder. Fresh premium fuel always works best on temperamental engines.
SOURCE: my 49cc pocket bike starts but wont stay on when i
That problem has happened to me to and i just ajusted the needle on the side becuase it was too rich or the breather on the gas tank sometimes that gets fratured and the gas fumes cant get out right
